/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:3494: => VIC Configuration failed image scale factor exceeds 16, use GPU for Transformation
0:11:09.117843227 17172 0x55aedbd2d0 WARN nvinfer gstnvinfer.cpp:1277:convert_batch_and_push_to_input_thread:<secondary_gie_0> error: NvBufSurfTransform failed with error -2 while converting buffer
ERROR from secondary_gie_0: NvBufSurfTransform failed with error -2 while converting buffer
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1277): convert_batch_and_push_to_input_thread (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstNvInfer:secondary_gie_0
• DeepStream Version
• TensorRT Version
Jetson NX
deepstream-app version 5.1.0
DeepStreamSDK 5.1.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.1
cuDNN Version: 8.0
Issue Type ,bugs
when run secondary gie,it produce the issue
deepstream_app_config.txt (2.8 KB)
config_infer_primary.txt (642 Bytes)
config_infer_secondary_safebelt.txt (653 Bytes)
VIC scale factor can’t bigger than 16.
OK,thank you
