Nope, but the deepstream docker image works, so i’m pretty sure it’s not driver related.
My repositories are:
[user@host] -- [/etc/apt/sources.list.d]
$ cat cuda.list nvidia-docker.list nvidia-machine-learning.list
deb http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 /
deb https://nvidia.github.io/libnvidia-container/ubuntu18.04/$(ARCH) /
deb https://nvidia.github.io/nvidia-container-runtime/ubuntu18.04/$(ARCH) /
deb https://nvidia.github.io/nvidia-docker/ubuntu18.04/$(ARCH) /
deb http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 /
Steps to repro:
[user@host] -- [~/Projects/Columbia/builddir/columbia]
$ arch
x86_64
$ gst-launch-1.0 videotestsrc num-buffers=300 ! 'video/x-raw, width=(int)1280, height=(int)720, \
format=(string)I420, framerate=(fraction)30/1' ! nvvideoconvert ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvv4l2h264enc ! fakesink
Setting pipeline to PAUSED ...
Failed to query video capabilities: Invalid argument
libv4l2: error getting capabilities: Invalid argument
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0: Error getting capabilities for device '/dev/nvhost-msenc': It isn't a v4l2 driver. Check if it is a v4l1 driver.
Additional debug info:
v4l2_calls.c(98): gst_v4l2_get_capabilities (): /GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0:
system error: Invalid argument
Setting pipeline to NULL ...
Freeing pipeline ...
Additional diagnostics:
[user@host] -- [/opt/nvidia/deepstream/deepstream/lib/gst-plugins]
$ file libgstnvvideo4linux2.so
libgstnvvideo4linux2.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=47cc2bad744bd86cbd93dca63454c2efda549b99, not stripped
$ gst-inspect-1.0 $(pwd)/libgstnvvideo4linux2.so
Plugin Details:
Name nvvideo4linux2
Description Nvidia elements for Video 4 Linux
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so
Version 1.14.0
License LGPL
Source module nvvideo4linux2
Binary package nvvideo4linux2
Origin URL http://nvidia.com/
nvv4l2decoder: NVIDIA v4l2 video decoder
nvv4l2h264enc: V4L2 H.264 Encoder
nvv4l2h265enc: V4L2 H.265 Encoder
nvv4l2vp8enc: V4L2 VP8 Encoder
nvv4l2vp9enc: V4L2 VP9 Encoder
5 features:
+-- 5 elements
$ nvidia-smi
Tue Jul 21 18:16:31 2020
| NVIDIA-SMI 440.95.01 Driver Version: 440.95.01 CUDA Version: 10.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce GTX 1080 On | 00000000:01:00.0 On | N/A |
| 0% 39C P8 9W / 200W | 1MiB / 8116MiB | 0% Default |
| 1 GeForce GTX 1080 On | 00000000:02:00.0 Off | N/A |
| 0% 42C P8 8W / 200W | 1MiB / 8119MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
More info about this box, including a full package set, can be found here.
