• Hardware Platform: Jetson AGX Orin
• DeepStream Version: 6.3
• JetPack Version 5.1.2 (r35.4.1)
• TensorRT Version: 8.5.2-1+cuda11.4
• Issue Type: Bug
We’re trying to use the nvv4l2h264enc plugin to encode a test video source but it seems like there’s an issue with the driver.
run gst-launch-1.0 -v videotestsrc ! nvvidconv ! "video/x-raw(memory:NVMM)" ! nvv4l2h264enc ! fakesink; you should get the following output:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
libv4l2: error getting capabilities: Inappropriate ioctl for device
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0: Error getting capabilities for device '/dev/nvhost-msenc': It isn't a v4l2 driver. Check if it is a v4l1 driver.
Additional debug info:
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/v4l2_calls.c(94): gst_v4l2_get_capabilities (): /GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0:
system error: Inappropriate ioctl for device
Setting pipeline to NULL ...
Freeing pipeline ...
I’ve attached the stack trace below:
out.txt (223.3 KB)
