Hi All,
I’m trying to compile ROOT (http://root.cern.ch/drupal/) on the jetson TK1 but am running into errors:
/home/ubuntu/ROOT/root/math/vc/src/cpuid.cpp:129:13: error: impossible constraint in ‘asm’
CPUID(0);
/home/ubuntu/ROOT/root/math/vc/src/cpuid.cpp:132:13: error: impossible constraint in ‘asm’
CPUID(1);
/home/ubuntu/ROOT/root/math/vc/src/cpuid.cpp:161:22: error: impossible constraint in ‘asm’
CPUID(0x80000001);
/home/ubuntu/ROOT/root/math/vc/src/cpuid.cpp:168:26: error: impossible constraint in ‘asm’
CPUID(0x80000005);
/home/ubuntu/ROOT/root/math/vc/src/cpuid.cpp:175:26: error: impossible constraint in ‘asm’
CPUID(0x80000006);
/home/ubuntu/ROOT/root/math/vc/src/cpuid.cpp:189:17: error: impossible constraint in ‘asm’
CPUID(2);
/home/ubuntu/ROOT/root/math/vc/src/cpuid.cpp:225:26: error: impossible constraint in ‘asm’
CPUID_C(4, i);
I’ve compiled ROOT many times on many different linux ARM boards (even fedora21 for this specific board) and haven’t run into these errors before. This could be a bug in the Assembly routines coded into Nvidia’s Ubuntu?
Just to follow up, I finally got ROOT compiled. It seems theres an issue with the VC libraries (solved by adding --disable-vc) as well as the GSL and mathmore libraries (solved by adding --disable-mathmore). I had all the optionals installed which ROOT found and then failed on.
However, there seems to still be a lot of bugs with tegra ubuntu kernel/OS. I finally gave up trying to run an analysis in ROOT.
If possible, could you elaborate on the bugs that you’ve found with the kernel or the OS, and provide logs if applicable? We’d like to investigate the issues and see if we can possibly resolve them.
Hi Chris,
I can’t supply the logs unfortunately, i’ve re-flashed and put fedora21 on the jetson. But it should be fairly easy to reproduce.
ROOT failures are triggered using the optional dependencies shown here https://root.cern.ch/drupal/content/build-prerequisites for ubuntu. Specifically, gsl and vc libraries gave me errors. I couldn’t tell you what the specific bugs in the jetson kernel are, but I have been able to build ROOT on all forms of linux (arm and intel) until now.
Sorry, not much, but I hope that helps.
Josh
