Hi, I want to use camera sensors while headless, but I got an error in creating camera sensor handle.
It is same problem as the below link:
Continuing the discussion from Error using camera in headless mode
I’ve followed other topics too but it did not work.
Also I can run the interop_torch.py example too.
Please give any solution to resolve the problem.
Hi @seong_drgn
The problem comes from vec_task.py line 89
else:
print("GPU Pipeline can only be used with GPU simulation. Forcing CPU Pipeline.")
config["sim"]["use_gpu_pipeline"] = False
self.rl_device = rl_device
# Rendering
# if training in a headless mode
self.headless = headless
enable_camera_sensors = config.get("enableCameraSensors", False)
self.graphics_device_id = graphics_device_id
if enable_camera_sensors == False and self.headless == True:
self.graphics_device_id = -1
self.num_environments = config["env"]["numEnvs"]
self.num_agents = config["env"].get("numAgents", 1) # used for multi-agent environments
self.num_observations = config["env"]["numObservations"]
self.num_states = config["env"].get("numStates", 0)
self.num_actions = config["env"]["numActions"]
The configuration for enabling camera sensors (enableCameraSensors) in Isaac Gym environments is defined at task.env.enableCameraSensors however, the configuration in the script is looking at task.enableCameraSensors.
Because this last sub-key does not exist, enable_camera_sensors = config.get("enableCameraSensors", False) is always returning False. Then, when headless is True, the final graphics_device_id is -1
To create and set the sub-key, when running the script, use +task.enableCameraSensors=True
Example:
python train.py task=Cartpole headless=True +task.enableCameraSensors=True
Or edit the vec_task.py line 89
enable_camera_sensors = config["env"].get("enableCameraSensors", False)
and use the original configuration sub-key:
Example:
python train.py task=Cartpole headless=True task.env.enableCameraSensors=True
system
Closed
January 31, 2023, 8:36pm
3
