Both
• DeepStream Version
7.0 and 7.1
• TensorRT Version
Documentation error
This issue was first reported with Error in DeepStream 7.0 installation instructions - symlink fails to create at which time the Topic was labeled with "nvbugs"
. However, the error still exists in the 7.1 installation instructions.
If you follow the directions and Install librdkafka using the following commands:
$ sudo mkdir -p /opt/nvidia/deepstream/deepstream/lib
$ sudo cp /usr/local/lib/librdkafka* /opt/nvidia/deepstream/deepstream/lib
and then install the DeepStream SDK, you are left with the following directory setup
with the Kafka libs under /opt/nvidia/deepstream/deepstream/libs
and the SDK installed under /opt/nvidia/deepstream/deepstream-7.1/...
with a missing symlink that’s required from /opt/nvidia/deepstream/deepstream/
to /opt/nvidia/deepstream/deepstream-7.1/
The DeepStream installer is failing to create the symlink since the /opt/nvidia/deepstream/deepstream/
folder all ready exists… as it was created in the Kafka install section.
Any application that tries to link the DeepStream code using the symlink will fail after the upgrade.
The easiest way to fix the documentation is to just change the order of the installation steps and install the DeepStream SDK before copying the Kafka libs.
I’ve confirmed that the installation completes with all files correctly under deepstream-7.1
and a valid symlink as show below.
An alternative fix would be to go back to the approach used in releases prior to 7.0… see 6.3 Kafka install
