I find an error when trying to install pycuda on WSL2 (Windows 10) following the command:
pip install pycuda
the error log is huge but it closes with:
ERROR: Failed building wheel for pycuda
Failed to build pycuda
ERROR: Could not build wheels for pycuda, which is required to install pyproject.toml-based projects
I also attached the full log to this post
I already tested the nvidia-smi command to verify if there is the right configuration of the GPUs and there is not problem.
| NVIDIA-SMI 545.23.07 Driver Version: 546.12 CUDA Version: 12.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX A4500 On | 00000000:17:00.0 Off | Off |
| 30% 28C P8 9W / 200W | 0MiB / 20470MiB | 0% Default |
| | | N/A |
| 1 NVIDIA RTX A4500 On | 00000000:73:00.0 On | Off |
| 30% 31C P8 12W / 200W | 1509MiB / 20470MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
I also called the GPUs on tensorflow following tf.config.get_visible_devices('GPU') and it finds my GPUs.
[PhysicalDevice(name='/physical_device:GPU:0', device_type='GPU'), PhysicalDevice(name='/physical_device:GPU:1', device_type='GPU')]
I’m running out of ideas of what could be happening. Could you help me to understand what I’m missing? Thanks!
pycuda.log (2.5 MB)
