I came across github issue discussing the same - Installing Error · Issue #6 · NVIDIA/tao_tutorials · GitHub. It is still in open state.
Hope this give some clues in troubleshooting this.
Hi, I can install tao launcher successfully in WSL ubuntu 22.04.
Step:
info "Installed jupyter"
echo "export PATH=\"$(PATH):\$HOME/.local/bin\"" >> ~/.bashrc
source ~/.bashrc
jupyter --version | grep jupyter_core
Attach full log.
20250506_install_tao_launcher_in_wsl_ubuntu22_full.txt (374.8 KB)
Thank you for trying out in WSL and confirming it is working. Much appreciated.
I checked what all services are running and exited. I noticed that apparmor.service is in failed status. Could that be the reason?
UNIT LOAD ACTIVE SUB DESCRIPTION
accounts-daemon.service loaded active running Accounts Service
acpid.service loaded active running ACPI event daemon
● apparmor.service loaded failed failed Load AppArmor profiles
apport.service loaded active exited LSB: automatic crash report generation
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
blk-availability.service loaded active exited Availability of block devices
chrony.service loaded active running chrony, an NTP client/server
cloud-config.service loaded active exited Cloud-init: Config Stage
cloud-final.service loaded active exited Cloud-init: Final Stage
cloud-init-local.service loaded active exited Cloud-init: Local Stage (pre-network)
cloud-init.service loaded active exited Cloud-init: Network Stage
colord.service loaded active running Manage, Install and Generate Color Profiles
console-setup.service loaded active exited Set console font and keymap
containerd.service loaded active running containerd container runtime
cron.service loaded active running Regular background program processing daemon
cups-browsed.service loaded active running Make remote CUPS printers available locally
cups.service loaded active running CUPS Scheduler
dbus.service loaded active running D-Bus System Message Bus
docker.service loaded active running Docker Application Container Engine
ephemeral-disk-warning.service loaded active exited Write warning to Azure ephemeral disk
finalrd.service loaded active exited Create final runtime dir for shutdown pivot root
gdm.service loaded active running GNOME Display Manager
hv-kvp-daemon.service loaded active running Hyper-V KVP Protocol Daemon
irqbalance.service loaded active running irqbalance daemon
kerneloops.service loaded active running Tool to automatically collect and submit kernel crash signatures
keyboard-setup.service loaded active exited Set the console keyboard layout
kmod-static-nodes.service loaded active exited Create List of Static Device Nodes
lvm2-monitor.service loaded active exited Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
ModemManager.service loaded active running Modem Manager
multipathd.service loaded active running Device-Mapper Multipath Device Controller
networkd-dispatcher.service loaded active running Dispatcher daemon for systemd-networkd
NetworkManager-wait-online.service loaded active exited Network Manager Wait Online
NetworkManager.service loaded active running Network Manager
nvidia-gridd.service loaded active running NVIDIA Grid Daemon
nvidia-persistenced.service loaded active running NVIDIA Persistence Daemon
openvpn.service loaded active exited OpenVPN service
packagekit.service loaded active running PackageKit Daemon
plymouth-quit-wait.service loaded active exited Hold until boot process finishes up
plymouth-read-write.service loaded active exited Tell Plymouth To Write Out Runtime Data
polkit.service loaded active running Authorization Manager
power-profiles-daemon.service loaded active running Power Profiles daemon
rsyslog.service loaded active running System Logging Service
rtkit-daemon.service loaded active running RealtimeKit Scheduling Policy Service
serial-getty@ttyS0.service loaded active running Serial Getty on ttyS0
setvtrgb.service loaded active exited Set console scheme
snapd.apparmor.service loaded active exited Load AppArmor profiles managed internally by snapd
snapd.seeded.service loaded active exited Wait until snapd is fully seeded
snapd.service loaded active running Snap Daemon
ssh.service loaded active running OpenBSD Secure Shell server
switcheroo-control.service loaded active running Switcheroo Control Proxy service
sysstat.service loaded active exited Resets System Activity Logs
systemd-binfmt.service loaded active exited Set Up Additional Binary Formats
systemd-fsck-root.service loaded active exited File System Check on Root Device
systemd-fsck@dev-disk-by\x2duuid-F3C9\x2d4183.service loaded active exited File System Check on /dev/disk/by-uuid/F3C9-4183
systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running User Login Management
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-networkd-wait-online.service loaded active exited Wait for Network to be Configured
systemd-networkd.service loaded active running Network Configuration
systemd-oomd.service loaded active running Userspace Out-Of-Memory (OOM) Killer
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
systemd-resolved.service loaded active running Network Name Resolution
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-sysusers.service loaded active exited Create System Users
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories
systemd-udev-trigger.service loaded active exited Coldplug All udev Devices
systemd-udevd.service loaded active running Rule-based Manager for Device Events and Files
systemd-update-utmp.service loaded active exited Record System Boot/Shutdown in UTMP
systemd-user-sessions.service loaded active exited Permit User Sessions
udisks2.service loaded active running Disk Manager
ufw.service loaded active exited Uncomplicated firewall
unattended-upgrades.service loaded active running Unattended Upgrades Shutdown
upower.service loaded active running Daemon for power management
user-runtime-dir@1000.service loaded active exited User Runtime Directory /run/user/1000
user-runtime-dir@133.service loaded active exited User Runtime Directory /run/user/133
user@1000.service loaded active running User Manager for UID 1000
user@133.service loaded active running User Manager for UID 133
walinuxagent-network-setup.service loaded active exited Setup network rules for WALinuxAgent
walinuxagent.service loaded active running Azure Linux Agent
wpa_supplicant.service loaded active running WPA supplicant
xrdp-sesman.service loaded active running xrdp session manager
xrdp.service loaded active running xrdp daemon
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
85 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
lines 39-92/92 (END)
Can you please check the status at your end too - systemctl list-units --type=service?
morganh@NV-2Z8YZ84:/mnt/c/Users/morganh$ systemctl list-units --type=service
console-getty.service loaded active running Console Getty
getty@tty1.service loaded active running Getty on tty1
systemd-timedated.service loaded active running Time & Date Service
systemd-timesyncd.service loaded active running Network Time Synchronization
systemd-tmpfiles-setup-dev-early.service loaded active exited Create Static Device Nodes in /dev gracefully
wsl-pro.service loaded active running Bridge to Ubuntu Pro agent on Windows
Legend: LOAD → Reflects whether the unit definition was properly loaded.
ACTIVE → The high-level unit activation state, i.e. generalization of SUB.
SUB → The low-level unit activation state, values depend on unit type.
30 loaded units listed. Pass --all to see loaded but inactive units, too.
Thanks for the quick try out. Let me do a fresh install on WSL again. I will keep you posted.
Thank you for the detailed support. Highly appreciated.
This is not yet solved for me. I will try this again after few days and reopen the thread.
I started with cuOpt in mean time.
Yes, please refer to my previous step to try again. If there is new error, please create a new topic.
