Hello!
Thanks for getting back on this issue.
I just did a fresh sync of the rhel8 cuda repo on satellite 6.9
Mind you, satellite uses upstream ‘pulp’ to sync these, hence the some vague answer from RedHat…
The below, is all output I got when syncing.
I would be happy to test any thing you throw at us. :)
Action:
Actions::Pulp::Repository::Sync
Input:
{"source_url"=>nil,
"repo_id"=>17302,
"smart_proxy_id"=>1,
"remote_user"=>"admin",
"remote_cp_user"=>"admin",
"current_request_id"=>nil,
"current_timezone"=>"Europe/Copenhagen",
"current_user_id"=>13,
"current_organization_id"=>1,
"current_location_id"=>2}
Output:
{"pulp_tasks"=>
[{"exception"=>nil,
"task_type"=>"pulp.server.managers.repo.sync.sync",
"_href"=>"/pulp/api/v2/tasks/09f643c3-255b-411b-aa01-594b2b72799c/",
"task_id"=>"09f643c3-255b-411b-aa01-594b2b72799c",
"tags"=>
["pulp:repository:0c749c19-6694-476a-b612-2b4902bba817",
"pulp:action:sync"],
"finish_time"=>"2021-06-10T15:28:31Z",
"_ns"=>"task_status",
"start_time"=>"2021-06-10T15:28:03Z",
"traceback"=>
"Traceback (most recent call last):\n" +
" File \"/usr/lib/python2.7/site-packages/celery/app/trace.py\", line 367, in trace_task\n" +
" R = retval = fun(*args, **kwargs)\n" +
" File \"/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py\", line 688, in __call__\n" +
" return super(Task, self).__call__(*args, **kwargs)\n" +
" File \"/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py\", line 110, in __call__\n" +
" return super(PulpTask, self).__call__(*args, **kwargs)\n" +
" File \"/usr/lib/python2.7/site-packages/celery/app/trace.py\", line 622, in __protected_call__\n" +
" return self.run(*args, **kwargs)\n" +
" File \"/usr/lib/python2.7/site-packages/pulp/server/controllers/repository.py\", line 860, in sync\n" +
" raise pulp_exceptions.PulpExecutionException(_('Importer indicated a failed response'))\n" +
"PulpExecutionException: Importer indicated a failed response\n",
"spawned_tasks"=>[],
"progress_report"=>
{"yum_importer"=>
{"content"=>
{"items_total"=>0,
"state"=>"FINISHED",
"error_details"=>[],
"details"=>
{"rpm_total"=>0, "rpm_done"=>0, "drpm_total"=>0, "drpm_done"=>0},
"size_total"=>0,
"size_left"=>0,
"items_left"=>0},
"comps"=>{"state"=>"NOT_STARTED"},
"purge_duplicates"=>{"state"=>"NOT_STARTED"},
"distribution"=>
{"items_total"=>0,
"items_left"=>0},
"modules"=>
{"state"=>"FAILED",
"error"=>
"strings in documents must be valid UTF-8: '\\x8c\\x01\\x00\\x00\\x04465-dkms\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04418-dkms\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04450\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04440\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04460\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04455\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04465\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04440-dkms\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04455-dkms\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04460-dkms\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04latest-dkms\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04450-dkms\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04418\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x04latest\\x00\\x14\\x00\\x00\\x00\\x020\\x00\\x08\\x00\\x00\\x00default\\x00\\x00\\x00'"},
"errata"=>{"state"=>"NOT_STARTED"},
"metadata"=>{"state"=>"FINISHED"}}},
"queue"=>"reserved_resource_worker-3@satapp01pl.unicph.domain.dq2",
"state"=>"error",
"worker_name"=>"reserved_resource_worker-3@satapp01pl.unicph.domain",
"result"=>nil,
"error"=>
{"code"=>"PLP0000",
"data"=>{},
"description"=>"Importer indicated a failed response",
"sub_errors"=>[]},
"_id"=>{"$oid"=>"60c22f8386a9c963de52393d"},
"id"=>"60c22f8386a9c963de52393d"}],
"contents_changed"=>true,
"poll_attempts"=>{"total"=>18, "failed"=>1}}
Exception:
Katello::Errors::PulpError: PLP0000: Importer indicated a failed response
Backtrace:
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/pulp/abstract_async_task.rb:121:in `block in external_task='
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/pulp/abstract_async_task.rb:119:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/pulp/abstract_async_task.rb:119:in `external_task='
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/pulp/repository/sync.rb:29:in `external_task='
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action/polling.rb:100:in `poll_external_task_with_rescue'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action/polling.rb:22:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action/cancellable.rb:14:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/pulp/abstract_async_task.rb:45:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:571:in `block (3 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:27:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware.rb:19:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware.rb:32:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/stack.rb:23:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/middleware/remote_action.rb:16:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/middleware/remote_action.rb:40:in `block in as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/models/katello/concerns/user_extensions.rb:21:in `cp_config'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/middleware/remote_action.rb:27:in `as_cp_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/middleware/remote_action.rb:39:in `as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.18.1.22/app/lib/actions/middleware/remote_action.rb:16:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/rails_executor_wrap.rb:14:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.4/lib/active_support/execution_wrapper.rb:88:in `wrap'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/rails_executor_wrap.rb:13:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action/progress.rb:31:in `with_progress_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action/progress.rb:17:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_request_id.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_request_id.rb:49:in `restore_current_request_id'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_request_id.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_timezone.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_timezone.rb:44:in `restore_curent_timezone'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_timezone.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_user.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_user.rb:44:in `restore_curent_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_user.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_taxonomies.rb:45:in `restore_current_taxonomies'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-3.0.5/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/middleware/world.rb:31:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:570:in `block (2 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:569:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:569:in `block in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:472:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:472:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:472:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:564:in `execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/action.rb:285:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in `block (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract.rb:167:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in `open_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/director.rb:93:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:11:in `block (2 levels) in perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors.rb:18:in `run_user_code'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:9:in `block in perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:25:in `with_telemetry'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/worker_jobs.rb:8:in `perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.7/lib/dynflow/executors/sidekiq/serialization.rb:27:in `perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:192:in `execute_job'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:165:in `block (2 levels) in process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:128:in `block in invoke'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:133:in `invoke'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:164:in `block in process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:137:in `block (6 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:109:in `local'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:136:in `block (5 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq.rb:37:in `block in <module:Sidekiq>'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:132:in `block (4 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:250:in `stats'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:127:in `block (3 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_logger.rb:8:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:126:in `block (2 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:74:in `global'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:125:in `block in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:48:in `with_context'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:42:in `with_job_hash_context'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:124:in `dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:163:in `process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:83:in `process_one'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:71:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:16:in `watchdog'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:25:in `block in safe_thread'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
Action:
Input:
{"source_url"=>nil,
"repo_id"=>17302,
Output:
{"pulp_tasks"=>
[{"exception"=>nil,
"tags"=>
"traceback"=>
"progress_report"=>
{"yum_importer"=>
{"content"=>
{"items_total"=>0,
"details"=>
"size_total"=>0,
"size_left"=>0,
"items_left"=>0},
"distribution"=>
{"items_total"=>0,
"items_left"=>0},
"modules"=>
{"state"=>"FAILED",
"error"=>
"state"=>"error",
"result"=>nil,
"error"=>
{"code"=>"PLP0000",
"data"=>{},
"sub_errors"=>[]},
Action:
Actions::Pulp::Orchestration::Repository::Sync
Input:
{"subaction_output"=>Step(4).output,
Output:
Action:
Actions::Katello::Repository::IndexContent
Input:
{"id"=>17302,
"contents_changed"=>Step(6).output[:contents_changed],
Output:
Action:
Actions::Katello::Repository::ErrataMail
Input:
{"repo"=>17302,
"last_updated"=>"2021-06-10 17:28:03 +0200",
Output:
Action:
Input:
{"repo"=>17302,
Output:
Action:
Actions::Pulp::Repository::RegenerateApplicability
Input:
{"repository_id"=>17302,
Output:
Action:
Actions::Katello::Repository::Sync
Input:
{"repository"=>{"id"=>17302, "name"=>"el8_x86_64", "label"=>"el8_x86_64"},
"product"=>
{"id"=>147,
"name"=>"Nvidia Cuda",
"label"=>"Nvidia_Cuda",
"cp_id"=>"978461087049"},
"provider"=>{"id"=>1, "name"=>"Anonymous"},
"organization"=>{"id"=>1, "name"=>"KU", "label"=>"Default_Organization"},
"services_checked"=>["pulp", "pulp_auth"],
"id"=>17302,
"sync_result"=>Step(6).output,
"skip_metadata_check"=>false,
"validate_contents"=>false,
Output:
Action:
Input:
"product"=>
{"id"=>147,
"id"=>17302,
Output:
Action:
Actions::Katello::Repository::ImportApplicability
Input:
{"repo_id"=>17302,
Output:
