Conditions:
I’m creating ALPR system like this: Creating a Real-Time License Plate Detection and Recognition App | NVIDIA Technical Blog
Speaking about ‘License plate recognition’
Launching on PC : tlt lprnet train
Driver Version: 465.19.01
CUDA Version: 11.3
TensorRT: 7.2.3
cudnn: 8.2.0.53
deepstream-app version 5.1.0
DeepStreamSDK 5.1.0
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
alex@jetson:~$ tlt info --verbose
Configuration of the TLT Instance
dockers:
nvcr.io/nvidia/tlt-streamanalytics:
docker_tag: v3.0-dp-py3
tasks:
1. augment
2. classification
3. detectnet_v2
4. dssd
5. emotionnet
6. faster_rcnn
7. fpenet
8. gazenet
9. gesturenet
10. heartratenet
11. lprnet
12. mask_rcnn
13. retinanet
14. ssd
15. unet
16. yolo_v3
17. yolo_v4
18. tlt-converter
nvcr.io/nvidia/tlt-pytorch:
tasks:
1. speech_to_text
2. text_classification
3. question_answering
4. token_classification
5. intent_slot_classification
6. punctuation_and_capitalization
format_version: 1.0
tlt_version: 3.0
published_date: 02/02/2021
• Training spec file(If have, please share here)
tutorial_spec_ru.txt (2.4 KB)
random_seed: 42
lpr_config {
hidden_units: 512
max_label_length: 9
arch: “baseline”
nlayers: 18 #setting nlayers to be 10 to use baseline10 model
training_config {
batch_size_per_gpu: 32
num_epochs: 24
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 1e-6
max_learning_rate: 1e-5
soft_start: 0.001
annealing: 0.5
regularizer {
type: L2
weight: 5e-4
eval_config {
validation_period_during_training: 5
batch_size: 1
augmentation_config {
output_width: 96
output_height: 48
output_channel: 3
keep_original_prob: 0.3
transform_prob: 0.5
rotate_degree: 5
dataset_config {
data_sources: {
label_directory_path: “/workspace/tlt-experiments/data/openalpr/train/label”
image_directory_path: “/workspace/tlt-experiments/data/openalpr/train/image”
characters_list_file: “/workspace/tlt-experiments/lprnet/specs/ru_lp_characters.txt”
validation_data_sources: {
label_directory_path: “/workspace/tlt-experiments/data/openalpr/val/label”
image_directory_path: “/workspace/tlt-experiments/data/openalpr/val/image”
ru_lp_characters.txt contains:
0
1
2
3
4
5
6
7
8
9
A
B
E
K
M
H
O
P
C
T
Y
X
D
Error
alex@jetson:~$ tlt lprnet train -e /workspace/tlt-experiments/lprnet/tutorial_spec.txt -r /workspace/tlt-experiments/lprnet/ -k nvidia_tlt -m /workspace/tlt-experiments/lprnet/us_lprnet_baseline18_trainable.tlt
2021-07-06 11:11:35,706 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-07-06 08:11:42,448 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-07-06 08:11:42,448 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:56: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-07-06 08:11:42,557 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:56: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:59: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-07-06 08:11:42,558 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:59: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:60: The name tf.keras.backend.set_session is deprecated. Please use tf.compat.v1.keras.backend.set_session instead.
2021-07-06 08:11:44,541 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py:60: The name tf.keras.backend.set_session is deprecated. Please use tf.compat.v1.keras.backend.set_session instead.
2021-07-06 08:11:44,542 [INFO] /usr/local/lib/python3.6/dist-packages/iva/lprnet/utils/spec_loader.pyc: Merging specification from /workspace/tlt-experiments/lprnet/tutorial_spec_ru.txt
2021-07-06 08:11:44,545 [INFO] main: Loading pretrained weights. This may take a while…
The shape of this layer does not match original model: td_dense
Loading the model as a pruned model.
WARNING:tensorflow:No training configuration found in save file: the model was not compiled. Compile it manually.
2021-07-06 08:12:19,613 [WARNING] tensorflow: No training configuration found in save file: the model was not compiled. Compile it manually.
Initialize optimizer
Model: “lpnet_baseline_18”
Layer (type) Output Shape Param # Connected to
image_input (InputLayer) [(None, 3, 48, 96)] 0
tf_op_layer_Sum (TensorFlowOpLa (None, 1, 48, 96) 0 image_input[0][0]
conv1 (Conv2D) (None, 64, 48, 96) 640 tf_op_layer_Sum[0][0]
bn_conv1 (BatchNormalization) (None, 64, 48, 96) 256 conv1[0][0]
re_lu (ReLU) (None, 64, 48, 96) 0 bn_conv1[0][0]
max_pooling2d (MaxPooling2D) (None, 64, 48, 96) 0 re_lu[0][0]
res2a_branch2a (Conv2D) (None, 64, 48, 96) 36928 max_pooling2d[0][0]
bn2a_branch2a (BatchNormalizati (None, 64, 48, 96) 256 res2a_branch2a[0][0]
re_lu_1 (ReLU) (None, 64, 48, 96) 0 bn2a_branch2a[0][0]
res2a_branch1 (Conv2D) (None, 64, 48, 96) 4160 max_pooling2d[0][0]
res2a_branch2b (Conv2D) (None, 64, 48, 96) 36928 re_lu_1[0][0]
bn2a_branch1 (BatchNormalizatio (None, 64, 48, 96) 256 res2a_branch1[0][0]
bn2a_branch2b (BatchNormalizati (None, 64, 48, 96) 256 res2a_branch2b[0][0]
tf_op_layer_add (TensorFlowOpLa (None, 64, 48, 96) 0 bn2a_branch1[0][0]
bn2a_branch2b[0][0]
re_lu_2 (ReLU) (None, 64, 48, 96) 0 tf_op_layer_add[0][0]
res2b_branch2a (Conv2D) (None, 64, 48, 96) 36928 re_lu_2[0][0]
bn2b_branch2a (BatchNormalizati (None, 64, 48, 96) 256 res2b_branch2a[0][0]
re_lu_3 (ReLU) (None, 64, 48, 96) 0 bn2b_branch2a[0][0]
res2b_branch2b (Conv2D) (None, 64, 48, 96) 36928 re_lu_3[0][0]
bn2b_branch2b (BatchNormalizati (None, 64, 48, 96) 256 res2b_branch2b[0][0]
tf_op_layer_add_1 (TensorFlowOp (None, 64, 48, 96) 0 re_lu_2[0][0]
bn2b_branch2b[0][0]
re_lu_4 (ReLU) (None, 64, 48, 96) 0 tf_op_layer_add_1[0][0]
res3a_branch2a (Conv2D) (None, 128, 24, 48) 73856 re_lu_4[0][0]
bn3a_branch2a (BatchNormalizati (None, 128, 24, 48) 512 res3a_branch2a[0][0]
re_lu_5 (ReLU) (None, 128, 24, 48) 0 bn3a_branch2a[0][0]
res3a_branch1 (Conv2D) (None, 128, 24, 48) 8320 re_lu_4[0][0]
res3a_branch2b (Conv2D) (None, 128, 24, 48) 147584 re_lu_5[0][0]
bn3a_branch1 (BatchNormalizatio (None, 128, 24, 48) 512 res3a_branch1[0][0]
bn3a_branch2b (BatchNormalizati (None, 128, 24, 48) 512 res3a_branch2b[0][0]
tf_op_layer_add_2 (TensorFlowOp (None, 128, 24, 48) 0 bn3a_branch1[0][0]
bn3a_branch2b[0][0]
re_lu_6 (ReLU) (None, 128, 24, 48) 0 tf_op_layer_add_2[0][0]
res3b_branch2a (Conv2D) (None, 128, 24, 48) 147584 re_lu_6[0][0]
bn3b_branch2a (BatchNormalizati (None, 128, 24, 48) 512 res3b_branch2a[0][0]
re_lu_7 (ReLU) (None, 128, 24, 48) 0 bn3b_branch2a[0][0]
res3b_branch2b (Conv2D) (None, 128, 24, 48) 147584 re_lu_7[0][0]
bn3b_branch2b (BatchNormalizati (None, 128, 24, 48) 512 res3b_branch2b[0][0]
tf_op_layer_add_3 (TensorFlowOp (None, 128, 24, 48) 0 re_lu_6[0][0]
bn3b_branch2b[0][0]
re_lu_8 (ReLU) (None, 128, 24, 48) 0 tf_op_layer_add_3[0][0]
res4a_branch2a (Conv2D) (None, 256, 12, 24) 295168 re_lu_8[0][0]
bn4a_branch2a (BatchNormalizati (None, 256, 12, 24) 1024 res4a_branch2a[0][0]
re_lu_9 (ReLU) (None, 256, 12, 24) 0 bn4a_branch2a[0][0]
res4a_branch1 (Conv2D) (None, 256, 12, 24) 33024 re_lu_8[0][0]
res4a_branch2b (Conv2D) (None, 256, 12, 24) 590080 re_lu_9[0][0]
bn4a_branch1 (BatchNormalizatio (None, 256, 12, 24) 1024 res4a_branch1[0][0]
bn4a_branch2b (BatchNormalizati (None, 256, 12, 24) 1024 res4a_branch2b[0][0]
tf_op_layer_add_4 (TensorFlowOp (None, 256, 12, 24) 0 bn4a_branch1[0][0]
bn4a_branch2b[0][0]
re_lu_10 (ReLU) (None, 256, 12, 24) 0 tf_op_layer_add_4[0][0]
res4b_branch2a (Conv2D) (None, 256, 12, 24) 590080 re_lu_10[0][0]
bn4b_branch2a (BatchNormalizati (None, 256, 12, 24) 1024 res4b_branch2a[0][0]
re_lu_11 (ReLU) (None, 256, 12, 24) 0 bn4b_branch2a[0][0]
res4b_branch2b (Conv2D) (None, 256, 12, 24) 590080 re_lu_11[0][0]
bn4b_branch2b (BatchNormalizati (None, 256, 12, 24) 1024 res4b_branch2b[0][0]
tf_op_layer_add_5 (TensorFlowOp (None, 256, 12, 24) 0 re_lu_10[0][0]
bn4b_branch2b[0][0]
re_lu_12 (ReLU) (None, 256, 12, 24) 0 tf_op_layer_add_5[0][0]
res5a_branch2a (Conv2D) (None, 300, 12, 24) 691500 re_lu_12[0][0]
bn5a_branch2a (BatchNormalizati (None, 300, 12, 24) 1200 res5a_branch2a[0][0]
re_lu_13 (ReLU) (None, 300, 12, 24) 0 bn5a_branch2a[0][0]
res5a_branch1 (Conv2D) (None, 300, 12, 24) 77100 re_lu_12[0][0]
res5a_branch2b (Conv2D) (None, 300, 12, 24) 810300 re_lu_13[0][0]
bn5a_branch1 (BatchNormalizatio (None, 300, 12, 24) 1200 res5a_branch1[0][0]
bn5a_branch2b (BatchNormalizati (None, 300, 12, 24) 1200 res5a_branch2b[0][0]
tf_op_layer_add_6 (TensorFlowOp (None, 300, 12, 24) 0 bn5a_branch1[0][0]
bn5a_branch2b[0][0]
re_lu_14 (ReLU) (None, 300, 12, 24) 0 tf_op_layer_add_6[0][0]
res5b_branch2a (Conv2D) (None, 300, 12, 24) 810300 re_lu_14[0][0]
bn5b_branch2a (BatchNormalizati (None, 300, 12, 24) 1200 res5b_branch2a[0][0]
re_lu_15 (ReLU) (None, 300, 12, 24) 0 bn5b_branch2a[0][0]
res5b_branch2b (Conv2D) (None, 300, 12, 24) 810300 re_lu_15[0][0]
bn5b_branch2b (BatchNormalizati (None, 300, 12, 24) 1200 res5b_branch2b[0][0]
tf_op_layer_add_7 (TensorFlowOp (None, 300, 12, 24) 0 re_lu_14[0][0]
bn5b_branch2b[0][0]
re_lu_16 (ReLU) (None, 300, 12, 24) 0 tf_op_layer_add_7[0][0]
permute_feature (Permute) (None, 24, 12, 300) 0 re_lu_16[0][0]
flatten_feature (Reshape) (None, 24, 3600) 0 permute_feature[0][0]
lstm (LSTM) (None, 24, 512) 8423424 flatten_feature[0][0]
td_dense (TimeDistributed) (None, 24, 36) 18468 lstm[0][0]
softmax (Softmax) (None, 24, 36) 0 td_dense[0][0]
Total params: 14,432,480
Trainable params: 14,424,872
Non-trainable params: 7,608
2021-07-06 08:12:20,258 [INFO] main: Number of images in the training dataset: 44164
2021-07-06 08:12:20,258 [INFO] main: Number of images in the validation dataset: 4954
Epoch 1/24
1/1381 […] - ETA: 4:46:55 - loss: 30.6878WARNING:tensorflow:Method (on_train_batch_end) is slow compared to the batch update (1.531048). Check your callbacks.
2021-07-06 08:12:33,920 [WARNING] tensorflow: Method (on_train_batch_end) is slow compared to the batch update (1.531048). Check your callbacks.
1380/1381 [============================>.] - ETA: 0s - loss: 1.51595d5412b7fe57:38:60 [0] NCCL INFO Bootstrap : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.2<0>
5d5412b7fe57:38:60 [0] NCCL INFO NET/Plugin : No plugin found (libnccl-net.so), using internal implementation
5d5412b7fe57:38:60 [0] NCCL INFO NET/IB : No device found.
5d5412b7fe57:38:60 [0] NCCL INFO NET/Socket : Using [0]lo:127.0.0.1<0> [1]eth0:172.17.0.2<0>
5d5412b7fe57:38:60 [0] NCCL INFO Using network Socket
NCCL version 2.7.8+cuda11.1
5d5412b7fe57:38:60 [0] NCCL INFO Channel 00/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 01/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 02/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 03/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 04/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 05/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 06/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 07/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 08/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 09/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 10/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 11/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 12/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 13/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 14/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 15/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 16/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 17/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 18/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 19/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 20/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 21/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 22/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 23/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 24/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 25/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 26/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 27/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 28/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 29/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 30/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Channel 31/32 : 0
5d5412b7fe57:38:60 [0] NCCL INFO Trees [0] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [1] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [2] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [3] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [4] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [5] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [6] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [7] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [8] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [9] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [10] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [11] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [12] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [13] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [14] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [15] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [16] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [17] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [18] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [19] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [20] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [21] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [22] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [23] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [24] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [25] -1/-1/-1->0->-1|-1->0->-1/-1/-1 [26] -1/-1/-1->0->-1|-1->0->-1/-
5d5412b7fe57:38:60 [0] NCCL INFO 32 coll channels, 32 p2p channels, 32 p2p channels per peer
5d5412b7fe57:38:60 [0] NCCL INFO comm 0x7f4642f34040 rank 0 nranks 1 cudaDev 0 busId 1000 - Init COMPLETE
Epoch 00001: saving model to /workspace/tlt-experiments/lprnet/weights/lprnet_epoch-01.tlt
1381/1381 [==============================] - 159s 115ms/step - loss: 1.5151
Epoch 2/24
1380/1381 [============================>.] - ETA: 0s - loss: 0.2815
Epoch 00002: saving model to /workspace/tlt-experiments/lprnet/weights/lprnet_epoch-02.tlt
1381/1381 [==============================] - 132s 95ms/step - loss: 0.2815
Epoch 3/24
1380/1381 [============================>.] - ETA: 0s - loss: 0.2369
Epoch 00003: saving model to /workspace/tlt-experiments/lprnet/weights/lprnet_epoch-03.tlt
1381/1381 [==============================] - 135s 98ms/step - loss: 0.2369
Epoch 4/24
1380/1381 [============================>.] - ETA: 0s - loss: 0.2174
Epoch 00004: saving model to /workspace/tlt-experiments/lprnet/weights/lprnet_epoch-04.tlt
1381/1381 [==============================] - 141s 102ms/step - loss: 0.2175
Epoch 5/24
1380/1381 [============================>.] - ETA: 0s - loss: 0.2088
Epoch 00005: saving model to /workspace/tlt-experiments/lprnet/weights/lprnet_epoch-05.tlt
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py”, line 274, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py”, line 270, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/train.py”, line 195, in run_experiment
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training.py”, line 727, in fit
use_multiprocessing=use_multiprocessing)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training_generator.py”, line 603, in fit
steps_name=‘steps_per_epoch’)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/engine/training_generator.py”, line 332, in model_iteration
callbacks.on_epoch_end(epoch, epoch_logs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/keras/callbacks.py”, line 299, in on_epoch_end
callback.on_epoch_end(epoch, logs)
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/callbacks/ac_callback.py”, line 65, in on_epoch_end
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/callbacks/ac_callback.py”, line 42, in _get_accuracy
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/utils/ctc_decoder.py”, line 33, in decode_ctc_conf
IndexError: list index out of range
File “/usr/local/bin/lprnet”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/entrypoint/lprnet.py”, line 12, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py”, line 296, in launch_job
AssertionError: Process run failed.
2021-07-06 11:24:01,934 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
If i add extra letters, till 35, like in us_lp_characters.txt - error disappeared but there are too much extra wrong letters in recognition of number plate
Question: how to tune that
