I have successfully installed Theano, a GPU optimized Python package for evaluating large scale mathematical expressions, on Windows 7 x64 for Python 3. When I was running theano.test(), the Python kernel died. Here’s part of the error messages, which are more related to CUDA than Theano as I believe:
....Error when tring to find the memory information on the GPU: unspecified launch failure
Error freeing device pointer 0000000200140000 (unspecified launch failure). Driver report zd bytes free and zd bytes total
CudaNdarray_uninit: error freeing self->devdata. (self=0000000024533B70, self->devata=0000000200140000)
Error freeing device pointer 0000000200140200 (unspecified launch failure). Driver report zd bytes free and zd bytes total
device_free: cudaFree() returned an error, but there is already an Python error set. This happen during the clean up when there is a first error and the CUDA driver is in a so bad state that it don't work anymore. We keep the previous error set to help debugging it.CudaNdarray_uninit: error freeing self->devdata. (self=0000000024533970, self->devata=0000000200140200)
Error freeing device pointer 0000000200140A00 (unspecified launch failure). Driver report zd bytes free and zd bytes total
device_free: cudaFree() returned an error, but there is already an Python error set. This happen during the clean up when there is a first error and the CUDA driver is in a so bad state that it don't work anymore. We keep the previous error set to help debugging it.CudaNdarray_uninit: error freeing self->devdata. (self=00000000240096F0, self->devata=0000000200140A00)
Error freeing device pointer 0000000200140C00 (unspecified launch failure). Driver report zd bytes free and zd bytes total
device_free: cudaFree() returned an error, but there is already an Python error set. This happen during the clean up when there is a first error and the CUDA driver is in a so bad state that it don't work anymore. We keep the previous error set to help debugging it.CudaNdarray_uninit: error freeing dev_structure memory 0000000200140C00 (self=00000000240096F0)
Error when trying to find the memory information on the GPU: unspecified launch failure
Any ideas for these errors? Thank you.
