Error when using multiview with push constants
Hi! Since I use a multiview I’ve this error :
validation layer: vkCmdDraw(): Shader in VK_SHADER_STAGE_VERTEX_BIT uses push-constant statically but vkCmdPushConstants was not called yet for pipeline layout VkPipelineLayout 0xafccd500000003ee.
The Vulkan spec states: If the maintenance4 feature is not enabled, then for each push constant that is statically used by a bound shader, a push constant value must have been set for the same pipeline bind point, with a VkPipelineLayout that is compatible for push constants, with the VkPipelineLayout used to create the current VkPipeline or the VkDescriptorSetLayout and VkPushConstantRange arrays used to create the current VkShaderEXT , as described in Pipeline Layout Compatibility (https://vulkan.lunarg.com/doc/view/1.4.309.0/windows/antora/spec/latest/chapters/drawing.html#VUID-vkCmdDraw-maintenance4-08602)
I don’t understand why I’ve this error, here is my vertex shader code :
const std::string  linkedListVertexShader2 = R"(#version 460
        #extension GL_EXT_multiview : enable
        layout (location = 0) in vec3 position;
        layout (location = 1) in vec4 color;
        layout (location = 2) in vec2 texCoords;
        layout (location = 3) in vec3 normals;
        layout (push_constant)uniform PushConsts {
        mat4 projectionMatrix;
        mat4 viewMatrix;
        mat4 worldMat;
        } pushConsts;
        layout (location = 0) out vec4 frontColor;
        layout (location = 1) out vec2 fTexCoords;
        layout (location = 2) out uint layer;
        layout (location = 3) out vec3 normal;
        void main () {
        gl_Position = vec4(position, 1.f) * pushConsts.worldMat * pushConsts.viewMatrix * pushConsts.projectionMatrix;
        gl_PointSize = 2.0f;
        frontColor = color;
        fTexCoords = texCoords;
        normal = normals;
        layer = gl_ViewIndex;
And I set push constant ranges like this :
for (unsigned int j = 0; j < NBDEPTHSTENCIL; j++) {
                    for (unsigned int i = 0; i < Batcher::nbPrimitiveTypes - 1; i++) {
                        if (j == 0) {
                           VkPushConstantRange push_constant;
                           //this push constant range starts at the beginning
                           push_constant.offset = 0;
                           //this push constant range takes up the size of a MeshPushConstants struct
                           push_constant.size = sizeof(LinkedList2PC);
                           //this push constant range is accessible only in the vertex shader
                           push_constant.stageFlags = VK_SHADER_STAGE_VERTEX_BIT;
                           pipelineLayoutInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][NODEPTHNOSTENCIL].pPushConstantRanges = &push_constant;
                           pipelineLayoutInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][NODEPTHNOSTENCIL].pushConstantRangeCount = 1;
                           depthStencilCreateInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][NODEPTHNOSTENCIL].depthCompareOp = VK_COMPARE_OP_ALWAYS;
                           depthStencilCreateInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][NODEPTHNOSTENCIL].front = {};
                           depthStencilCreateInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][NODEPTHNOSTENCIL].back = {};
                           environmentMap.createGraphicPipeline(static_cast<sf::PrimitiveType>(i), states, NODEPTHNOSTENCIL, NBDEPTHSTENCIL);
                        } else {
                           pipelineLayoutInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][DEPTHNOSTENCIL].pPushConstantRanges = &push_constant;
                           pipelineLayoutInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][DEPTHNOSTENCIL].pushConstantRangeCount = 1;
                           depthStencilCreateInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][DEPTHNOSTENCIL].depthCompareOp = VK_COMPARE_OP_GREATER;
                           depthStencilCreateInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][DEPTHNOSTENCIL].front = {};
                           depthStencilCreateInfo[sLinkedList2.getId() * (Batcher::nbPrimitiveTypes - 1)+i][environmentMap.getId()][DEPTHNOSTENCIL].back = {};
                           environmentMap.createGraphicPipeline(static_cast<sf::PrimitiveType>(i), states, DEPTHNOSTENCIL, NBDEPTHSTENCIL);
And I call vkCmdPushConstants but event when calling this command I get the error message.
void ReflectRefractRenderComponent::createCommandBufferVertexBuffer(RenderStates currentStates) {
                environmentMap.beginRecordCommandBuffers();
                Shader* shader = const_cast<Shader*>(currentStates.shader);
                unsigned int currentFrame = environmentMap.getCurrentFrame();
                std::vector<VkCommandBuffer> commandBuffers = environmentMap.getCommandBuffers();
                vkCmdPipelineBarrier(commandBuffers[currentFrame], VK_PIPELINE_STAGE_COLOR_ATTACHMENT_OUTPUT_BIT, VK_PIPELINE_STAGE_FRAGMENT_SHADER_BIT, 0, 0, nullptr, 0, nullptr, 0, nullptr);
                VkMemoryBarrier memoryBarrier;
                memoryBarrier.sType = VK_STRUCTURE_TYPE_MEMORY_BARRIER;
                memoryBarrier.pNext = VK_NULL_HANDLE;
                memoryBarrier.srcAccessMask = VK_ACCESS_SHADER_READ_BIT | VK_ACCESS_SHADER_WRITE_BIT;
                memoryBarrier.dstAccessMask = VK_ACCESS_SHADER_READ_BIT | VK_ACCESS_SHADER_WRITE_BIT;
                vkCmdPipelineBarrier(commandBuffers[currentFrame], VK_PIPELINE_STAGE_FRAGMENT_SHADER_BIT, VK_PIPELINE_STAGE_FRAGMENT_SHADER_BIT, 0, 1, &memoryBarrier, 0, nullptr, 0, nullptr);
                vkCmdPushConstants(commandBuffers[currentFrame], environmentMap.getPipelineLayout()[shader->getId() * (Batcher::nbPrimitiveTypes - 1) + vb.getPrimitiveType()][environmentMap.getId()][NODEPTHNOSTENCIL], VK_SHADER_STAGE_VERTEX_BIT, 0, sizeof(LinkedList2PC), &linkedList2PC);
                environmentMap.drawVertexBuffer(commandBuffers[currentFrame], currentFrame, vb, NODEPTHNOSTENCIL, currentStates);
                environmentMap.display();
Ok I’ve solved this by adding the maintenance4 feature.
