Hello. I have pre-trained VGG16 net with 7 classes. When I was using tensorflow without GPU I was achieving about 3s per one image classification. Now I am trying to boost it with GPU, but I found a small problem. I’m getting errors:
“W tensorflow/core/common_runtime/bfc_allocator.cc:219] Allocator (GPU_0_bfc) ran out of memory trying to allocate 1.79GiB. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.”
I tought TX1 has about 4GB memory. When I am looking into Tensorflow informations at startup:
“totalMemory: 3.89GiB freeMemory: 2.24GiB”
Why is the freeMemory so low?
My script is:
from socket import AF_INET, SOCK_DGRAM, socket
from keras.models import load_model
from keras.preprocessing import image
import numpy as np
from keras import optimizers
from keras import backend as K
from keras.backend.tensorflow_backend import set_session
from keras.backend.tensorflow_backend import clear_session
from keras.backend.tensorflow_backend import get_session
import tensorflow
import gc
# Reset Keras Session
def reset_keras():
sess = get_session()
clear_session()
sess.close()
try:
del model # this is from global space - change this as you need
except:
pass
print(gc.collect()) # if it's done something you should see a number being outputted
# use the same config as you used to create the session
config = tensorflow.ConfigProto()
config.gpu_options.per_process_gpu_memory_fraction = 1
config.gpu_options.visible_device_list = "0"
set_session(tensorflow.Session(config=config))
reset_keras()
K.clear_session()
# dimensions of our images
img_width, img_height = 454, 227
# load the model we saved
model = load_model('Models/vgg16_9.h5')
model.compile(loss='categorical_crossentropy',
optimizer=optimizers.Adam(lr=1e-4),
metrics=['acc'])
print(model.summary())
# predicting images
test_image = image.load_img('Photos/test.png', target_size = (227, 454))
test_image = image.img_to_array(test_image)
test_image = test_image/255
test_image = np.expand_dims(test_image, axis = 0)
result = model.predict(test_image, batch_size=1, verbose=1)
y_pred = np.argmax(result, axis = 1)
Is there a way I can achieve better times?
