Hi @DaneLLL, thank you for your tips.
1.
I tried making the suggested edits to the patch. However, the src pad format doesn’t get replaced by NV12 when I run:
gst-inspect-1.0 nvjpegdec
Output:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
format: { (string)I420, (string)GRAY8 }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
video/x-raw
format: { (string)I420, (string)RGB, (string)BGR, (string)RGBx, (string)xRGB, (string)BGRx, (string)xBGR, (string)GRAY8 }
I think that I somehow have to replace /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so as well in order to get the NV12 src format for nvjpegdec.
2.
Also, when I run the original patch (with the I420 format):
GST_DEBUG=2 gst-launch-1.0 -v v4l2src device=/dev/video0 io-mode=2 ! "image/jpeg,width=1920,height=1080, framerate=30/1" ! nvjpegdec ! 'video/x-raw(memory:NVMM), format=I420' ! nvivafilter cuda-process=true customer-lib-name="./aarch64/lib/libtest_share_lib_proj.so" ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! fakesink
I get an internal stream error, reason (-5):
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstNvJpegDec:nvjpegdec0.GstPad:sink: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
0:00:00.321233941 26079 0x558dfad590 WARN v4l2bufferpool gstv4l2bufferpool.c:790:gst_v4l2_buffer_pool_start:<v4l2src0:pool:src> Uncertain or not enough buffers, enabling copy threshold
/GstPipeline:pipeline0/GstNvJpegDec:nvjpegdec0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvivafilter:nvivafilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvivafilter:nvivafilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
0:00:00.737791182 26079 0x558dfad590 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop:<v4l2src0> <b>error: Internal data stream error.</b>
0:00:00.737848059 26079 0x558dfad590 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop:<v4l2src0> <b>error: streaming stopped, reason error (-5)</b>
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Execution ended after 0:00:00.427761074
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
However, when I insert “! video/x-raw ! nvvidconv” it works perfectly:
GST_DEBUG=2 gst-launch-1.0 -v v4l2src device=/dev/video0 io-mode=2 ! "image/jpeg,width=1920,height=1080, framerate=30/1" ! nvjpegdec ! video/x-raw ! nvvidconv ! 'video/x-raw(memory:NVMM), format=I420' ! nvivafilter cuda-process=true customer-lib-name="./aarch64/lib/libtest_share_lib_proj.so" ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! fakesink
I think it is somehow related to the flow of data between nvjpegdec and nvivafilter (because if I just output nvjpegdec to a fakesink it works). Also, my libtest_share_lib_proj.so is compiled from the original nvsample_cudaprocess.cu from the public sources (L4T sources, version 32.3.1).
Do you know how to fix these issues by any chance?
