I am trying to compile my cuda code but this error message was shown :
./a.out: error while loading shared libraries: libnvJitLink.so.12: cannot open shared object file: No such file or directory
I have cuda 12.2 version with latest hpc toolkit installed. They both came bundled. I have installed it in a custom location instead of /opt/ .
Any help will be great for me!
Thanks and regards
Abhishek Singh
You may need to set your LD_LIBRARY_PATH variable correctly. Using a file find utility, locate where libnvJitLink.so is on your system. Then set your LD_LIBRARY_PATH to include that location.
I did same just now. The output of the find utility is this:
./data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib/stubs/libnvJitLink.so
./data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib/libnvJitLink.so.12.2.91
./data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib/libnvJitLink_static.a
I then exported it as :
export LD_LIBRARY_PATH=/data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib/
Error is still same. Is there any thing I am missing?
The app is expecting libnvJitLink.so.12
For some reason that does not appear to be in your /data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib directory.
What is the result of:
ls /data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib
If you have root privilege, you could try doing:
ln -s -T /data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib/libnvJitLink.so.12.2.91 /data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib/libnvJitLink.so.12
Thank you for the response!
The result of l libnvJitLink* in that directory is :
libnvJitLink.so@ libnvJitLink.so.12.2.91*
libnvJitLink.so.12@ libnvJitLink_static.a*
You’re right, it is still unable to locate libnvJitLink.so.12
Here’s the output:
linux-vdso.so.1 (0x00007ffc55da9000)
libcublas.so.12 => /data/nvhpc/Linux_x86_64/23.7/math_libs/12.2/lib64/libcublas.so.12 (0x00007ff5bb9cf000)
libcusolver.so.11 => /data/nvhpc/Linux_x86_64/23.7/math_libs/12.2/lib64/libcusolver.so.11 (0x00007ff5b49c8000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007ff5b49af000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007ff5b498c000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007ff5b4986000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007ff5b47a2000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007ff5b4653000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007ff5b4638000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007ff5b4446000)
/lib64/ld-linux-x86-64.so.2 (0x00007ff5c232b000)
libcublasLt.so.12 => /data/nvhpc/Linux_x86_64/23.7/math_libs/12.2/lib64/libcublasLt.so.12 (0x00007ff59247c000)
libnvJitLink.so.12 => not found
libcusparse.so.12 => /data/nvhpc/Linux_x86_64/23.7/math_libs/12.2/lib64/libcusparse.so.12 (0x00007ff582733000)
what is the result of:
ls -l /data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib/libnvJitLink*
and
echo $LD_LIBRARY_PATH
Thank you @Robert_Crovella !
When I set the LD_LIBRARY_PATH to /data/nvhpc/Linux_x86_64/23.7/cuda/12.2/targets/x86_64-linux/lib/, it worked! All other location where libnvJitLink.so.12 was located didn’t worked.
Thank you for the help!
edit: /data/nvhpc/Linux_x86_64/23.1/cuda/12.2/targets/x86_64-linux/lib/
I thought you had done that already:
I did same. But it worked this time. And I also tried to export all other locations of nvJitLink. Only difference between then and now is I downgraded my cuda version bundled with HPC toolkit from 23.7 to 23.1 which is bundled with cuda 12.1
