Provide details on the platforms you are using:
Linux distro and version : Ubuntu 16.04 LTS
GPU type : GeForce GT 740M 2GB
nvidia driver version: 410.79
CUDA version : 9.0
CUDNN version : 7.1.3
Python version : 3.5.2
Tensorflow version : Tensorflow-gpu 1.10.0
TensorRT version : 4.0.1.6
I have a Tensorflow pretained model from https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/detection_model_zoo.md
called faster_rcnn_inception_resnet_v2_atrous_coco to be more precise.
But i’m not satisfied with time it takes to detect objects in images. So, I want to optimise this model with tensorRT to improve performace.
I copied script from tensorRT docs that should optimise frozen graph:
import tensorflow as tf
import tensorflow.contrib.tensorrt as trt
# Inference with TF-TRT frozen graph workflow:
graph = tf.Graph()
with graph.as_default():
with graph.device('gpu:0'):
with tf.Session() as sess:
with tf.gfile.GFile("/home/tomas/Downloads/frozen_inference_graph.pb", 'rb') as f:
graph_def = tf.GraphDef()
graph_def.ParseFromString(f.read())
# Now you can create a TensorRT inference graph from your
# frozen graph:
trt_graph = trt.create_inference_graph(
input_graph_def=graph_def,
outputs=["detection_boxes,detection_scores,detection_classes,num_detections"],
max_batch_size=1,
max_workspace_size_bytes=2147483648,
precision_mode="FP32")
# Import the TensorRT graph into a new graph and run:
output_node = tf.import_graph_def(
trt_graph,
return_elements=["detection_boxes,detection_scores,detection_classes,num_detections"])
sess.run(output_node)
and tried to run this code, but get this error:
[code]2019-02-22 01:11:00.636033: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:897] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-02-22 01:11:00.636955: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1405] Found device 0 with properties:
name: GeForce GT 740M major: 3 minor: 5 memoryClockRate(GHz): 1.0325
pciBusID: 0000:01:00.0
totalMemory: 1.96GiB freeMemory: 1.77GiB
2019-02-22 01:11:00.637003: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1484] Adding visible gpu devices: 0
2019-02-22 01:11:08.733633: I tensorflow/core/common_runtime/gpu/gpu_device.cc:965] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-02-22 01:11:08.733714: I tensorflow/core/common_runtime/gpu/gpu_device.cc:971] 0
2019-02-22 01:11:08.733770: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] 0: N
2019-02-22 01:11:08.741305: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1097] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 1525 MB memory) → physical GPU (device: 0, name: GeForce GT 740M, pci bus id: 0000:01:00.0, compute capability: 3.5)
WARNING:tensorflow:TensorRT mismatch. Compiled against version 3.0.4, but loaded 4.0.1. Things may not work
2019-02-22 01:11:12.544730: I tensorflow/core/grappler/devices.cc:51] Number of eligible GPUs (core count >= 8): 0
2019-02-22 01:11:13.052629: W tensorflow/core/framework/allocator.cc:108] Allocation of 20054016 exceeds 10% of system memory.
2019-02-22 01:11:13.130831: W tensorflow/core/framework/allocator.cc:108] Allocation of 12779520 exceeds 10% of system memory.
2019-02-22 01:11:14.043909: W tensorflow/core/framework/allocator.cc:108] Allocation of 20054016 exceeds 10% of system memory.
2019-02-22 01:11:14.043984: W tensorflow/core/framework/allocator.cc:108] Allocation of 20054016 exceeds 10% of system memory.
2019-02-22 01:11:14.426922: W tensorflow/core/framework/allocator.cc:108] Allocation of 12779520 exceeds 10% of system memory.
2019-02-22 01:11:28.760913: I tensorflow/contrib/tensorrt/convert/convert_graph.cc:756] MULTIPLE tensorrt candidate conversion: 111
2019-02-22 01:11:28.804144: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/’, converted to graph
2019-02-22 01:11:28.970041: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/’, converted to graph
2019-02-22 01:11:28.978826: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/’, converted to graph
2019-02-22 01:11:28.979270: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:794] Failed to register segment graphdef as a function 2: Invalid argument: Node ‘SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame/truediv/x’: Unknown input node ‘^SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/Identity’
2019-02-22 01:11:28.985227: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘map_1/while/’, converted to graph
2019-02-22 01:11:28.985669: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:794] Failed to register segment graphdef as a function 3: Invalid argument: Node ‘map_1/while/concat/axis’: Unknown input node ‘^map_1/while/Identity’
2019-02-22 01:11:28.992005: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘map/while/ToNormalizedCoordinates/’, converted to graph
2019-02-22 01:11:28.992473: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:794] Failed to register segment graphdef as a function 4: Invalid argument: Node ‘map/while/ToNormalizedCoordinates/truediv/x’: Unknown input node ‘^map/while/Identity’
2019-02-22 01:11:28.997743: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘Preprocessor/map/while/ResizeToRange/’, converted to graph
2019-02-22 01:11:28.998110: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:794] Failed to register segment graphdef as a function 5: Invalid argument: Node ‘Preprocessor/map/while/ResizeToRange/Const_1’: Unknown input node ‘^Preprocessor/map/while/Identity’
2019-02-22 01:11:29.004094: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘’, converted to graph
2019-02-22 01:11:29.011243: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘’, converted to graph
2019-02-22 01:11:29.018460: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘SecondStagePostprocessor/’, converted to graph
2019-02-22 01:11:29.089748: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘’, converted to graph
2019-02-22 01:11:43.451555: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/’, converted to graph
2019-02-22 01:11:44.691656: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:794] Failed to register segment graphdef as a function 10: Invalid argument: Node ‘SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/add_3/y’: Unknown input node ‘^SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/Identity’
2019-02-22 01:11:44.697628: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:44.817994: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:44.894365: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:44.971165: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.047877: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/’, converted to graph
2019-02-22 01:11:45.238223: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.315250: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.392783: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.471704: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.549244: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.628709: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.706039: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.783939: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.862898: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:45.941322: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘’, converted to graph
2019-02-22 01:11:46.019949: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘ClipToWindow/Area/’, converted to graph
2019-02-22 01:11:46.098679: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.178561: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.258823: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.338140: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.419743: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.500616: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.580620: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.661410: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.741418: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.822662: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.903009: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:46.984063: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.065027: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.146226: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.227333: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.310371: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.390263: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/’, converted to graph
2019-02-22 01:11:47.471915: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.553347: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.634342: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.715396: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.810167: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:47.926080: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.025025: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.125777: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.224114: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.321848: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.420400: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.520351: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.618961: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.716518: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:48.814640: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/’, converted to graph
2019-02-22 01:11:48.912810: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:49.010586: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:49.109044: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:49.207284: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageBoxPredictor/BoxEncodingPredictor/’, converted to graph
2019-02-22 01:11:49.304139: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘Preprocessor/’, converted to graph
2019-02-22 01:11:49.402663: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘GridAnchorGenerator/’, converted to graph
2019-02-22 01:11:49.501260: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:49.600710: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘’, converted to graph
2019-02-22 01:11:49.699554: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:49.799620: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:49.899584: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.001421: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘GridAnchorGenerator/’, converted to graph
2019-02-22 01:11:50.100515: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.200222: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.299956: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.399827: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.499460: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.601381: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.702817: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.805644: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:50.907651: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.010188: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.112661: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Area/’, converted to graph
2019-02-22 01:11:51.216503: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.318824: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.422578: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.532487: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.642254: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.753171: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.856571: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:51.961125: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:52.066102: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:52.171630: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘Preprocessor/map/while/ResizeToRange/’, converted to graph
2019-02-22 01:11:52.271069: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:794] Failed to register segment graphdef as a function 91: Invalid argument: Node ‘Preprocessor/map/while/ResizeToRange/Const’: Unknown input node ‘^Preprocessor/map/while/Identity’
2019-02-22 01:11:52.276922: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:52.384001: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:52.490690: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:52.595581: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:52.699998: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:52.805117: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:52.909800: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘GridAnchorGenerator/’, converted to graph
2019-02-22 01:11:53.018454: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘’, converted to graph
2019-02-22 01:11:53.124465: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:53.231156: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:53.337269: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:53.444302: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:53.551402: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:53.656758: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘GridAnchorGenerator/’, converted to graph
2019-02-22 01:11:53.768649: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘GridAnchorGenerator/Meshgrid_1/ExpandedShape/’, converted to graph
2019-02-22 01:11:53.875045: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/’, converted to graph
2019-02-22 01:11:53.979728: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘Conv/’, converted to graph
2019-02-22 01:11:54.112007: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageBoxPredictor/ClassPredictor/’, converted to graph
2019-02-22 01:11:54.220073: I tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2853] Segment @scope ‘FirstStageFeatureExtractor/InceptionResnetV2/’, converted to graph
2019-02-22 01:11:54.412708: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:11:54.534127: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:11:54.539373: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 0, composed of 3 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=-2. Skipping…
2019-02-22 01:11:54.539445: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:11:54.543230: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:11:54.543289: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 1, composed of 3 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=-2. Skipping…
2019-02-22 01:11:54.543313: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:11:54.564478: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 2, composed of 18 nodes failed: Invalid argument: addScale requires tensor with rank 3, SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/truediv. Skipping…
2019-02-22 01:11:54.564536: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:11:54.568108: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 3, composed of 18 nodes failed: Invalid argument: addScale requires tensor with rank 3, Decode/get_center_coordinates_and_sizes/truediv_1. Skipping…
2019-02-22 01:11:54.568139: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:11:54.572281: W tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2647] Type conversion failed for InputPH_0
2019-02-22 01:11:54.572319: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 4, composed of 3 nodes failed: Invalid argument: Unsupported data type int32. Skipping…
2019-02-22 01:11:54.572340: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:12.853306: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger runtime.cpp (16) - Cuda Error in allocate: 2
2019-02-22 01:13:19.332507: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger runtime.cpp (16) - Cuda Error in allocate: 2
2019-02-22 01:13:19.709143: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 5, composed of 491 nodes failed: Internal: Failed to build TensorRT engine. Skipping…
2019-02-22 01:13:19.724330: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.907166: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.907373: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 6, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.907474: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.913633: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.913748: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 7, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.913796: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.920189: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.920285: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 8, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.920331: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.925284: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.925337: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 9, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.925361: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.928490: W tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2647] Type conversion failed for InputPH_0
2019-02-22 01:13:19.928526: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 10, composed of 4 nodes failed: Invalid argument: Unsupported data type int32. Skipping…
2019-02-22 01:13:19.928548: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.932668: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.932708: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 11, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.932730: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.935780: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.935817: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 12, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.935837: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.938932: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.938970: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 13, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.938992: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.942053: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.942090: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 14, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.942111: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.945170: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.945205: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 15, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.945226: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.949126: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.949172: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 16, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.949192: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.952257: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.952290: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 17, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.952307: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.955383: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.955415: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 18, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.955433: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.959115: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:19.959163: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 19, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:19.959188: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:19.962566: W tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2647] Type conversion failed for InputPH_0
2019-02-22 01:13:19.962595: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 20, composed of 3 nodes failed: Invalid argument: Unsupported data type int32. Skipping…
2019-02-22 01:13:19.962611: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:22.974304: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:22.977839: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:22.977897: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 22, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:22.977922: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:22.981033: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:22.981067: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 23, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:22.981082: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:22.984521: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:22.984558: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 24, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:22.984576: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:22.988703: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:22.988757: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 25, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:22.988780: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:22.991896: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:22.991931: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 26, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:22.991947: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:22.995111: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:22.995145: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 27, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:22.995160: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:22.998247: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:22.998279: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 28, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:22.998294: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.002449: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.002508: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 29, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.002535: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.006392: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.006447: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 30, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.006468: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.009591: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.009629: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 31, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.009652: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.012880: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.012918: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 32, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.012941: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.016024: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.016056: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 33, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.016078: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.020226: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.020274: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 34, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.020300: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.024057: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.024106: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 35, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.024140: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.027960: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.028017: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 36, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.028056: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.031711: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.031757: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 37, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.031798: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.035901: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.035940: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 38, composed of 3 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=-2. Skipping…
2019-02-22 01:13:23.035967: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.039150: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.039197: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 39, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.039223: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.043735: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.043805: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 40, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.043834: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.048269: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.048319: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 41, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.048339: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.052303: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.052346: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 42, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.052374: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.055645: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.055683: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 43, composed of 716 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.055709: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.058872: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.058913: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 44, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.058940: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.062024: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.062062: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 45, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.062089: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.066048: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.066145: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 46, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.066169: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.070835: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.070912: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 47, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.070955: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.075787: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.075876: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 48, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.075899: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.080482: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.080536: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 49, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.080559: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.084910: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.084980: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 50, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.085009: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.088706: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.088744: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 51, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.088763: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.091848: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.091880: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 52, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.091898: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.095047: W tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2647] Type conversion failed for InputPH_0
2019-02-22 01:13:23.095078: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 53, composed of 4 nodes failed: Invalid argument: Unsupported data type int32. Skipping…
2019-02-22 01:13:23.095095: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.098978: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.099023: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 54, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.099046: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.102341: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.102384: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 55, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.102407: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.105517: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.105557: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 56, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.105580: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.108746: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.108786: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 57, composed of 4 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.108808: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.111855: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.111891: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 58, composed of 4 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=-2. Skipping…
2019-02-22 01:13:23.111913: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.115833: W tensorflow/contrib/tensorrt/convert/convert_nodes.cc:2647] Type conversion failed for InputPH_0
2019-02-22 01:13:23.115870: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 59, composed of 4 nodes failed: Invalid argument: Unsupported data type int32. Skipping…
2019-02-22 01:13:23.115893: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.118978: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.119018: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 60, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.119041: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.447800: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 61, composed of 18 nodes failed: Invalid argument: addScale requires tensor with rank 3, Decode/get_center_coordinates_and_sizes/truediv. Skipping…
2019-02-22 01:13:23.447912: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.453365: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.453468: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 62, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.453518: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.457668: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.457715: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 63, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.457746: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.462010: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.462058: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 64, composed of 14 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.462081: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.465528: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 65, composed of 8 nodes failed: Invalid argument: addScale requires tensor with rank 3, GridAnchorGenerator/mul_5. Skipping…
2019-02-22 01:13:23.465557: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.468809: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.468841: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 66, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.468856: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.471888: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.471918: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 67, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.471933: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.475001: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.475034: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 68, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.475049: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.478203: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.478241: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 69, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.478263: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.481315: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.481352: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 70, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.481373: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.484422: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.484459: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 71, composed of 6 nodes failed: Invalid argument: Failed to create Input layer tensor InputPH_0 rank=3. Skipping…
2019-02-22 01:13:23.484480: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:724] Can’t determine the device, constructing an allocator at device 0
2019-02-22 01:13:23.487559: E tensorflow/contrib/tensorrt/log/trt_logger.cc:38] DefaultLogger Parameter check failed at: …/builder/Network.cpp::addInput::364, condition: isValidDims(dims)
2019-02-22 01:13:23.487596: W tensorflow/contrib/tensorrt/convert/convert_graph.cc:857] Engine creation for segment 72, composed of 6 no
