Im trying to run gstreamer pipeline using deepstream and python.
This is the pipeline which is running successfully in terminal:
gst-launch-1.0 rtspsrc location="rtsp://admin:123456@192.168.0.150:554/H264?ch=1&subtype=0&proto=Onvif" latency=300 ! rtph264depay ! h264parse ! nvv4l2decoder drop-frame-interval=1 ! nvvideoconvert ! video/x-raw,width=1920,height=1080,formate=I420 ! queue ! nveglglessink window-x=0 window-y=0 window-width=1080 window-height=720
but while running the same pipeline using python code, im getting error as:
Error: gst-stream-error-quark: Internal data stream error. (1): gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstRTSPSrc:video-source/GstUDPSrc:udpsrc2:
streaming stopped, reason not-linked (-1)
This is the code that im using to run the gstreamer command:
import gi
import sys
gi.require_version("Gst", "1.0")
from gi.repository import Gst, GObject
def bus_call(bus, message, loop):
t = message.type
if t == Gst.MessageType.EOS:
sys.stdout.write("End-of-stream\n")
loop.quit()
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
sys.stderr.write("Error: %s: %s\n" % (err, debug))
loop.quit()
return True
def main(device):
GObject.threads_init()
Gst.init(None)
pipeline = Gst.Pipeline()
source = Gst.ElementFactory.make("rtspsrc", "video-source")
source.set_property("location", device)
source.set_property("latency", 300)
pipeline.add(source)
depay = Gst.ElementFactory.make("rtph264depay", "depay")
pipeline.add(depay)
source.link(depay)
parse = Gst.ElementFactory.make("h264parse", "parse")
pipeline.add(parse)
depay.link(parse)
decoder = Gst.ElementFactory.make("nvv4l2decoder", "decoder")
decoder.set_property("drop-frame-interval", 2)
pipeline.add(decoder)
parse.link(decoder)
convert = Gst.ElementFactory.make("nvvideoconvert", "convert")
pipeline.add(convert)
decoder.link(convert)
caps = Gst.Caps.from_string("video/x-raw,width=1920,height=1080,formate=I420")
filter = Gst.ElementFactory.make("capsfilter", "filter")
filter.set_property("caps", caps)
pipeline.add(filter)
convert.link(filter)
queue = Gst.ElementFactory.make("queue", "queue")
pipeline.add(queue)
filter.link(queue)
sink = Gst.ElementFactory.make("nveglglessink", "video-sink")
sink.set_property("window-x", 0)
sink.set_property("window-y", 0)
sink.set_property("window-width", 1280)
sink.set_property("window-height", 720)
sink.set_property("sync", False)
pipeline.add(sink)
queue.link(sink)
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
pipeline.set_state(Gst.State.NULL)
if __name__ == "__main__":
main("rtsp://admin:123456@192.168.0.150:554/H264?ch=1&subtype=0&proto=Onvif")
Does anyone know what is the mistake? Thank you!
