I’m trying to run NVIDIA provided HPL benchmark on H100 server by referring: NVIDIA HPC-Benchmarks | NVIDIA NGC. I’m able to successfully ran it on single node but getting the below error while trying to run it on multiple nodes.
Below are the commands I’m giving for single and multiple node.
Single Node:
srun -N 1 -G 8 --ntasks-per-node=8 --partition=gpu --cpu-bind=none --mpi=pmix
–container-image=“nvcr.io#nvidia/hpc-benchmarks:23.10”
–container-mounts=“/nfs_shared/workspace/hpl-linux-x86_64/sample-dat:/my-dat-files”
./hpl.sh --dat /my-dat-files/HPL-8GPUs.dat
Multiple Nodes:
CONT='nvcr.io#nvidia/hpc-benchmarks:23.10'
srun -N 8 --ntasks-per-node=8 --cpu-bind=none --mpi=pmix \
--container-image="${CONT}" \
./hpl.sh --dat /workspace/hpl-linux-x86_64/sample-dat/HPL-64GPUs.dat
The error I'm getting as below:
[g42-h100-009:230329] PMIX ERROR: ERROR in file gds_ds12_lock_pthread.c at line 168
[g42-h100-009:230335] PMIX ERROR: ERROR in file gds_ds12_lock_pthread.c at line 168
[g42-h100-009:230347] PMIX ERROR: ERROR in file gds_ds12_lock_pthread.c at line 168
[g42-h100-009:230357] PMIX ERROR: ERROR in file gds_ds12_lock_pthread.c at line 168
[g42-h100-009:230365] PMIX ERROR: ERROR in file gds_ds12_lock_pthread.c at line 168
[g42-h100-009:230376] PMIX ERROR: ERROR in file gds_ds12_lock_pthread.c at line 168
[g42-h100-009:230386] PMIX ERROR: ERROR in file gds_ds12_lock_pthread.c at line 168
[g42-h100-009:230396] PMIX ERROR: ERROR in file gds_ds12_lock_pthread.c at line 168
HPL-NVIDIA 23.10.0 -- NVIDIA accelerated HPL benchmark -- NVIDIA
HPLinpack 2.1 -- High-Performance Linpack benchmark -- October 26, 2012
Written by A. Petitet and R. Clint Whaley, Innovative Computing Laboratory, UTK
Modified by Piotr Luszczek, Innovative Computing Laboratory, UTK
Modified by Julien Langou, University of Colorado Denver
An explanation of the input/output parameters follows:
T/V : Wall time / encoded variant.
N : The order of the coefficient matrix A.
NB : The partitioning blocking factor.
P : The number of process rows.
Q : The number of process columns.
Time : Time in seconds to solve the linear system.
Gflops : Rate of execution for solving the linear system.
The following parameter values will be used:
N : 753664
NB : 1024
PMAP : Column-major process mapping
P : 8
Q : 8
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Left
BCAST : 2ringM
DEPTH : 1
SWAP : Spread-roll (long)
L1 : no-transposed form
U : transposed form
EQUIL : no
ALIGN : 8 double precision words
- The matrix A is randomly generated for each test.
- The following scaled residual check will be computed:
||Ax-b||_oo / ( eps * ( || x ||_oo * || A ||_oo + || b ||_oo ) * N )
- The relative machine precision (eps) is taken to be 1.110223e-16
- Computational tests pass if scaled residuals are less than 16.0
HPL-NVIDIA ignores the following parameters from input file:
* Broadcast parameters
* Panel factorization parameters
* Look-ahead value
* L1 layout
* U layout
* Equilibration parameter
* Memory alignment parameter
HPL-NVIDIA settings from environment variables:
monitor_gpu from environment variable 0
warmup_end_prog from environment variable 5.0
test_loops from environment variable 1
hpl_cfg_cuda_vmm from environment variable 0
Device info:
Peak clock frequency 1980 MHz
SM 90
Number of SMs 132
Total memory available 79.11 GB
canUseHostPointerForRegisteredMem 1
canMapHostMemory 1
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/transport/transport.cpp:nvshmemi_transport_init:215: init failed for remote transport: ibrc
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 47] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/init/init.cu:843: non-zero status: 3 building transport map failed
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 41] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 43] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 27] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 45] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 31] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 29] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 51] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 33] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 35] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 39] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 49] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 55] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 37] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 53] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 32] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 48] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 25] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 44] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 28] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 42] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 26] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 46] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 24] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 40] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 52] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 36] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 30] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 50] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 34] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 54] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 38] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 6] Peer GPU 8 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 2] Peer GPU 8 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 8] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 18] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 22] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 11] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 1] Peer GPU 8 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 3] Peer GPU 8 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 19] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 21] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 12] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 13] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 10] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 9] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 15] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 14] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 7] Peer GPU 8 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 0] Peer GPU 8 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 4] Peer GPU 8 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 5] Peer GPU 8 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 20] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 23] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 17] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 16] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/modules/transport/ibrc/ibrc.cpp:nvshmemt_init:1811: neither nv_peer_mem, or nvidia_peermem detected. Skipping transport.
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 56] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 63] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 61] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 59] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 62] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 57] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 60] Peer GPU 0 is not accessible, exiting ...
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/topo/topo.cpp:420: [GPU 58] Peer GPU 0 is not accessible, exiting ...
[HPL TRACE] cuda_nvshmem_init: max=0.2660 (58) min=0.1137 (43)
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/host/init/init.cu:nvshmemi_check_state_and_init:933: nvshmem initialization failed, exiting
/dvs/p4/build/sw/rel/gpgpu/toolkit/r12.0/main_nvshmem/src/util/cs.cpp:23: non-zero status: 16: No such file or directory, exiting... mutex destroy failed
Any help or suggestions are appreciated!
