Hi !
I’m trying to execute a segnet example on my host machine in order to split the sky and the terrain on a picture (FCN AlexNet).
I’m using TensorRT 2.1 and my machine is on Ubuntu 16.04.
I have a pretrained model.
I use this command :
./segnet-console drone_0428.png output_0428.png \--prototxt=deploy.prototxt \--model=snapshot_iter_27132.caffemodel \--labels=fpv-labels.txt \--colors=fpv-deploy-colors.txt \--input_blob=data \--output_blob=score_fr
And i get this :
segnet-console
args (9): 0 [./segnet-console] 1 [drone_0428.png] 2 [output_0428.png] 3 [--prototxt=deploy.prototxt] 4 [--model=snapshot_iter_27132.caffemodel] 5 [--labels=fpv-labels.txt] 6 [--colors=fpv-deploy-colors.txt] 7 [--input_blob=data] 8 [--output_blob=score_fr]
segNet -- loading segmentation network model from:
-- prototxt: deploy.prototxt
-- model: snapshot_iter_27132.caffemodel
-- labels: fpv-labels.txt
-- colors: fpv-deploy-colors.txt
-- input_blob 'data'
-- output_blob 'score_fr'
-- batch_size 2
[GIE] attempting to open cache file snapshot_iter_27132.caffemodel.2.tensorcache
[GIE] cache file not found, profiling network model
terminate called after throwing an instance of 'nvinfer1::CudaError'
what(): std::exception
Aborted (core dumped)
Here is the backtrace from gdb :
#0 0x00007ffff715f428 in __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:54
#1 0x00007ffff716102a in __GI_abort () at abort.c:89
#2 0x00007fffeed4b84d in __gnu_cxx::__verbose_terminate_handler() ()
from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#3 0x00007fffeed496b6 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#4 0x00007fffeed49701 in std::terminate() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#5 0x00007fffeed49919 in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#6 0x00007ffff0fe15e8 in nvinfer1::throwCudaError(char const*, char const*, int, int, char const*)
() from /usr/lib/x86_64-linux-gnu/libnvinfer.so.3
#7 0x00007ffff0fe2f6d in nvinfer1::cudnn::hasNativeFp16() ()
#8 0x00007ffff1001e07 in nvinfer1::cudnn::HardwareContext::HardwareContext() ()
#9 0x00007ffff0ffcd25 in createInferBuilder_INTERNAL ()
#10 0x00007ffff751646b in nvinfer1::(anonymous namespace)::createInferBuilder(nvinfer1::ILogger&) ()
from /home/poudlard/TensorRT/jetson-inference-master/build/x86_64/lib/libjetson-inference.so
#11 0x00007ffff7516811 in tensorNet::ProfileModel(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, unsigned int, std::ostream&) ()
#12 0x00007ffff7516edf in tensorNet::LoadNetwork(char const*, char const*, char const*, char const*, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, unsigned int) ()
#13 0x00007ffff7514e2c in segNet::Create(char const*, char const*, char const*, char const*, char const*, char const*, unsigned int) ()
#14 0x00007ffff7514c40 in segNet::Create(int, char**) ()
#15 0x0000000000403140 in main ()
Any idea what I did wrong ? :(
Thanks a lot !
