Errore CUDA failure 'an illegal memory access was encountered'
• Lamda workstation GEFORCE RTX 2080 Ti
• Network Type Yolov4
•nvidia/tao/tao-toolkit-pyt: v3.21.11-py3
• Sprec file of yolov4
random_seed: 42
yolov4_config {
small_anchor_shape: “[(5.35, 3.90),(8.02, 8.41),(14.26, 5.49)]”
mid_anchor_shape: “[(15.15, 12.55),(28.45, 8.28),(25.85, 19.98)]”
big_anchor_shape: “[(48.05, 13.53),(57.05, 26.31),(112.87, 42.79)]”
box_matching_iou: 0.25
matching_neutral_box_iou: 0.5
arch: “resnet”
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 0.5
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 4
num_epochs: 300
enable_qat: false
checkpoint_interval: 5
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
#resume_model_path: “/workspace/tao-experiments/yolo_v4/experiment_dir_unpruned/weights/yolov4_resnet18_epoch_070.tlt”
pretrain_model_path: “/workspace/tao-experiments/yolo_v4/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5”
eval_config {
average_precision_mode: SAMPLE
batch_size: 4
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
force_on_cpu: false
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0.5
horizontal_flip: 0.5
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
randomize_input_shape_period: 0
mosaic_prob: 0.1
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
tfrecords_path: “/workspace/tao-experiments/data/training/tfrecords/train*”
image_directory_path: “/workspace/tao-experiments/data/training”
include_difficult_in_training: true
image_extension: “png”
target_class_mapping {
key: “vehicle”
value: “vehicle”
validation_data_sources: {
tfrecords_path: “/workspace/tao-experiments/data/val/tfrecords/val*”
image_directory_path: “/workspace/tao-experiments/data/val”
Hello to all,
i am trying to train a yolov4 model using a lambda workstation and geforce rtx 2080 Ti.
The workstation has 128 GB RAM.
When I start the training I get this error during the evaluation of the model how can I solve?
fcace4bde730: 72: 122 [0] init.cc:951 NCCL WARN Cuda failure ‘an illegal memory access was encountered’
I also have this problem -_-
Thanks for the update, would you please help to share how it’s resolved?
@antenuccialessio
Please share the full log. Thanks.
Unfortunately, in 3.21.11 version, there is an issue for “yolo_v4 evaluate”.
Please change to sequence format as below.
label_directory_path: “xxx”
image_directory_path: “xxx”
For training or evaluation on tfrecord files, please set
force_on_cpu : True
Setting it to True will force NMS to run on CPU during training. This is useful when using TFRecord dataset for validation during training since there is a known issue with TensorFlow NMS on GPU when using TFRecord dataset for validation. Note Note that this flag does not have any impact on TAO export and TensorRT/DeepStream inference.
See more in
https://docs.nvidia.com/tao/tao-toolkit/text/object_detection/yolo_v4.html#nms-config
