Hello, I had a problem, but I solved which is about extension in python.
when I get a extension through github. and then I check the autoload page,
then when I launch Isaac Sim, in the log file, it says it can’t find local path and then the extension program then never open, and even I can’t find. So I find ‘C:/Users/Hyeonsu/AppData/Local/ov/data/Kit/Isaac-Sim/2022.1/user.config.json’
and deleted the path that I stored, then everything worked fine.
please check the problem, It happened in window OS.
Hi - Sorry for the delay in the response. Let us know if you still having this issue/question with the latest Isaac Sim 2022.2.1 release.
