in the documentation for the TLT 3.0 the information to disable the online augmentation in the RetinaNet (lower note) is not quite correct and leads to errors. I use the TLT 3.0 version from 06.09.21 (v3.0-py3).
If the min and max parameters random_crop_scale and/or zoom_out_scale are both set to 1.0 or 1 as described in the note, the training aborts with the following error message:
ValueError: It must be `min_scale < max_scale`.
and if you set the random_crop_ar (min and max) parameters to 1 the following error message is generated:
ValueError: It must be `min_aspect_ratio < max_aspect_ratio`.
You can work around the problems with minimally different values (the following values are the smallest possible):
augmentation_config {
output_width: 672
output_height: 384
output_channel: 3
random_crop_min_scale: 0.9999999
random_crop_max_scale: 1.0
random_crop_min_ar: 0.9999999
random_crop_max_ar: 1.0
zoom_out_min_scale: 1.0
zoom_out_max_scale: 1.0000001
brightness: 0
contrast: 0
saturation: 0
hue: 0
random_flip: 0
Can you reproduce this discrepancy between documentation and program or I am doing something wrong?
P.S. I am very thankful that in v3.0-py3 compared to v3.0-dp-py3 there is now the possibility to turn off the online augmentation in the RetinaNet.
