I am having an issue monitoring RX SW drops on BlueField-3.
From the documentation, I understand that RX SW drops refer to “the number of dropped packets due to a lack of WQE for the associated QPs/RQs (excluding hairpin QPs/RQs).”
I found two official ways to observe this metric, but both seem unsupported on my system.
First, with ngauge, host_rx_transport_out_of_buffer_packets (0x10800002000000XX) appears to correspond to RX SW drops. However, when I try to monitor it, I get the following error:
tkhan@tkhan-XPS-8940:~$ sudo ngauge all-dual-port-bf3-host.yml
File "/opt/nvidia/ngauge/ngauge", line 39, in <module>
File "/opt/nvidia/ngauge/ngauge/runner.py", line 102, in start
ValueError: The following Data IDs are not supported on this HW: 0x1080000200000000.
Second, with DOCA Flow Tune, enabling full monitoring produces the following warning:
ubuntu@localhost:/opt/mellanox/doca/tools$ sudo ./doca_flow_tune monitor -f /tmp/flow_tune_cfg.json background --high-rate
2026-03-19 06:51:05 - flow_tune - WARNING - Live Flow Tune Server was not detected on the provided socket
2026-03-19 06:51:05 - flow_tune - WARNING - Could not detect a running DOCA Flow program, some features will be impacted
2026-03-19 06:51:05 - flow_tune - WARNING - HW counter “RX SW Drops” is not supported on current device
2026-03-19 06:51:05 - flow_tune - WARNING - HW counter “Hairpin Drops” is not supported on current device
2026-03-19 06:51:05 - flow_tune - INFO - Counters are being saved to the CSV file, press Ctrl-C to exit
^C
2026-03-19 06:51:14 - flow_tune - INFO - DOCA Flow Tune finished successfully
Is there any constraint, prerequisite, or device-specific limitation for enabling this hardware counter on BlueField-3?
Any comments or guidance would be extremely helpful.
Best regards,
Taekyoung
