Execution time dominated by 'Delayed Execution'
Hi. I have a windows 11 machine, using Visual Studio 2022, Nsight Systems 2023.1.2, GeForce 3080Ti, driver is 531.14, using CUDA 12.1.
I have a program, and I’ve been suspecting performance issue. This program has many kernel calls, one right after another, ALL data is on the GPU, there is no copying back and forth between the device and host during the main loop. I have profiled the program with Nsight Systems.
It seems like ‘blocked state’ is absolutely filled with ‘Delay Execution’. I just can’t seem to figure out what is going on here. I’ve obscured some names, but the kernels which are getting delayed are nothing special compared to any of the other kernels, which execute very fast. Sometimes, even very simple data moving kernels get delayed.
Can someone help me understand what is going on here? Thanks so much!
for (int i=0; i < MANY; i++) {
FuncA(data);
FuncB(data);
FuncA(data) {
kernel1<<<123,138>>>(data);
kernel2<<<123,138>>>(data);
kernel10<<<123,138>>>(data);
kernel11<<<123,138>>>(data);
FuncB similar to FuncA.
@jasoncohen
Thanks. I should also note, this program launches kernels from the host AND device. I’ve since read that maybe Nsight Systems doesn’t support dynamic parallelism, so perhaps that is the issue?
I’ve also tried the program in Ubuntu. The program has the same behavior and runtime, but Nsight Systems does NOT show the red blocked state. The pattern of execution looks similar, though.
I have a similar problem. I use DXR for path tracing and Optix for real-time denoising.
Before Optix was ​​enabled, it had 60 fps. After enabling Optix, it can only reach 30fps.
I didn’t do any sync ops (Neither shared/external semaphores, nor cudaDeviceSynchronize called). I just called optixDenoiserInvoke on a 2048x2048 RGBA16_FLOAT empty buffer, and the fps dropped seriously.
I can’t find the specific reason. In the Nisght System, an extra ~15 ms per frame is marked as "Delayed Execution"😔
What should I do to keep my fps from dropping so badly?
I think you might want to try to examine that area with Nsight Compute for deeper analysis on that region.
Linking in @liuyis in case he has other suggestions.
IIUC you are using graphics app/APIs rather than CUDA right? In that case linking @dofek for suggestions
I’m currently utilizing DX12 for ray tracing and CUDA for the OptiX denoiser within each frame. However, I’m struggling to maintain a high fps even though no sync ops added here.
