99% gpu use
it works somehow yet slow.
however there is a more updated version named detectron2 d
@AastaLLL next question is how to get detectron to take inputs from CSI sensor rather than usb camera
Wat might be the cause of the error below? I need 32gb Xavier in order to complete the execution?
[12/16 14:33:11 fvcore.common.checkpoint]: Loading checkpoint from meshrcnn://meshrcnn_R50.pth
[12/16 14:33:12 meshrcnn.data.meshrcnn_transforms]: Loading models from pix3d_s1_test...
[12/16 14:39:55 meshrcnn.data.meshrcnn_transforms]: Unique objects loaded: 735
[12/16 14:39:55 meshrcnn.data.datasets.pix3d]: Loaded 2530 images in COCO format from datasets/pix3d/pix3d_s1_test.json
[12/16 14:39:55 d2.data.build]: Distribution of instances among all 9 categories:
| category | #instances | category | #instances | category | #instances |
| bed | 213 | bookcase | 79 | chair | 1165 |
| desk | 154 | misc | 20 | sofa | 415 |
| table | 419 | tool | 11 | wardrobe | 54 |
| total | 2530 | | | | |
[12/16 14:39:55 d2.data.common]: Serializing 2530 elements to byte tensors and concatenating them all ...
[12/16 14:39:55 d2.data.common]: Serialized dataset takes 1.36 MiB
[12/16 14:39:55 meshrcnn.evaluation.pix3d_evaluation]: Loading unique objects from pix3d_s1_test...
[12/16 14:46:25 meshrcnn.evaluation.pix3d_evaluation]: Unique objects loaded: 735
[12/16 14:46:25 d2.evaluation.evaluator]: Start inference on 2530 images
/home/nvidia/detectron2/detectron2/modeling/roi_heads/fast_rcnn.py:124: UserWarning: This overload of nonzero is deprecated:
nonzero()
Consider using one of the following signatures instead:
nonzero(*, bool as_tuple) (Triggered internally at ../torch/csrc/utils/python_arg_parser.cpp:882.)
filter_inds = filter_mask.nonzero()
python3 tools/train_net.py --config-file configs/pix3d/meshrcnn_R50_FPN.yaml --eval-only MODEL.WEIGHTS meshrcnn://meshrcnn_R50.pth
** fvcore version of PathManager will be deprecated soon. **
** Please migrate to the version in iopath repo. **
https://github.com/facebookresearch/iopath
Command Line Args: Namespace(config_file='configs/pix3d/meshrcnn_R50_FPN.yaml', dist_url='tcp://127.0.0.1:50152', eval_only=True, machine_rank=0, num_gpus=1, num_machines=1, opts=['MODEL.WEIGHTS', 'meshrcnn://meshrcnn_R50.pth'], resume=False)
[12/16 14:33:03 detectron2]: Rank of current process: 0. World size: 1
[12/16 14:33:05 detectron2]: Environment info:
sys.platform linux
Python 3.6.9 (default, Oct 8 2020, 12:12:24) [GCC 8.4.0]
numpy 1.18.5
detectron2 0.3 @/home/nvidia/detectron2/detectron2
Compiler GCC 7.5
CUDA compiler CUDA 10.2
detectron2 arch flags 7.2
DETECTRON2_ENV_MODULE <not set>
PyTorch 1.7.0 @/home/nvidia/.local/lib/python3.6/site-packages/torch
PyTorch debug build True
GPU available True
GPU 0 Xavier (arch=7.2)
CUDA_HOME /usr/local/cuda-10.2
Pillow 7.2.0
torchvision 0.8.0a0+45f960c @/usr/local/lib/python3.6/dist-packages/torchvision-0.8.0a0+45f960c-py3.6-linux-aarch64.egg/torchvision
torchvision arch flags 7.2
fvcore 0.1.2.post20201216
cv2 4.4.0
PyTorch built with:
- GCC 7.5
- C++ Version: 201402
- OpenMP 201511 (a.k.a. OpenMP 4.5)
- NNPACK is enabled
- CPU capability usage: NO AVX
- CUDA Runtime 10.2
- NVCC architecture flags: -gencode;arch=compute_53,code=sm_53;-gencode;arch=compute_62,code=sm_62;-gencode;arch=compute_72,code=sm_72
- CuDNN 8.0
- Build settings: BLAS=MKL, BUILD_TYPE=Release, CXX_FLAGS= -Wno-deprecated -fvisibility-inlines-hidden -DUSE_PTHREADPOOL -fopenmp -DNDEBUG -DUSE_XNNPACK -DUSE_VULKAN_WRAPPER -O2 -fPIC -Wno-narrowing -Wall -Wextra -Werror=return-type -Wno-missing-field-initializers -Wno-type-limits -Wno-array-bounds -Wno-unknown-pragmas -Wno-sign-compare -Wno-unused-parameter -Wno-unused-variable -Wno-unused-function -Wno-unused-result -Wno-unused-local-typedefs -Wno-strict-overflow -Wno-strict-aliasing -Wno-error=deprecated-declarations -Wno-stringop-overflow -Wno-psabi -Wno-error=pedantic -Wno-error=redundant-decls -Wno-error=old-style-cast -fdiagnostics-color=always -faligned-new -Wno-unused-but-set-variable -Wno-maybe-uninitialized -fno-math-errno -fno-trapping-math -Werror=format -DMISSING_ARM_VST1 -DMISSING_ARM_VLD1 -Wno-stringop-overflow, FORCE_FALLBACK_CUDA_MPI=1, USE_CUDA=ON, USE_EIGEN_FOR_BLAS=ON, USE_EXCEPTION_PTR=1, USE_GFLAGS=OFF, USE_GLOG=OFF, USE_MKL=OFF, USE_MKLDNN=OFF, USE_MPI=ON, USE_NCCL=0, USE_NNPACK=ON, USE_OPENMP=ON,
[12/16 14:51:33 d2.evaluation.evaluator]: Inference done 397/2530. 0.5933 s / img. ETA=0:27:13
[12/16 14:51:40 d2.evaluation.evaluator]: Inference done 406/2530. 0.5946 s / img. ETA=0:27:07
[12/16 14:51:45 d2.evaluation.evaluator]: Inference done 412/2530. 0.5968 s / img. ETA=0:27:05
[12/16 14:51:52 d2.evaluation.evaluator]: Inference done 416/2530. 0.5976 s / img. ETA=0:27:25
[12/16 14:51:59 d2.evaluation.evaluator]: Inference done 424/2530. 0.5989 s / img. ETA=0:27:19
[12/16 14:52:04 d2.evaluation.evaluator]: Inference done 433/2530. 0.5984 s / img. ETA=0:27:04
[12/16 14:52:09 d2.evaluation.evaluator]: Inference done 438/2530. 0.5986 s / img. ETA=0:27:06
[12/16 14:52:14 d2.evaluation.evaluator]: Inference done 443/2530. 0.6019 s / img. ETA=0:27:07
[12/16 14:52:19 d2.evaluation.evaluator]: Inference done 450/2530. 0.6030 s / img. ETA=0:27:00
[12/16 14:52:25 d2.evaluation.evaluator]: Inference done 458/2530. 0.6036 s / img. ETA=0:26:50
[12/16 14:52:30 d2.evaluation.evaluator]: Inference done 465/2530. 0.6055 s / img. ETA=0:26:44
[12/16 14:52:36 d2.evaluation.evaluator]: Inference done 471/2530. 0.6081 s / img. ETA=0:26:48
[12/16 14:52:42 d2.evaluation.evaluator]: Inference done 477/2530. 0.6107 s / img. ETA=0:26:48
[12/16 14:52:48 d2.evaluation.evaluator]: Inference done 483/2530. 0.6140 s / img. ETA=0:26:47
[12/16 14:52:53 d2.evaluation.evaluator]: Inference done 487/2530. 0.6163 s / img. ETA=0:26:54
[12/16 14:53:00 d2.evaluation.evaluator]: Inference done 491/2530. 0.6217 s / img. ETA=0:27:04
[12/16 14:53:06 d2.evaluation.evaluator]: Inference done 493/2530. 0.6300 s / img. ETA=0:27:21
[12/16 14:53:11 d2.evaluation.evaluator]: Inference done 497/2530. 0.6347 s / img. ETA=0:27:25
[12/16 14:53:21 d2.evaluation.evaluator]: Inference done 500/2530. 0.6371 s / img. ETA=0:27:55
[12/16 14:53:27 d2.evaluation.evaluator]: Inference done 503/2530. 0.6398 s / img. ETA=0:28:06
[12/16 14:53:32 d2.evaluation.evaluator]: Inference done 509/2530. 0.6422 s / img. ETA=0:28:03
[12/16 14:53:37 d2.evaluation.evaluator]: Inference done 514/2530. 0.6451 s / img. ETA=0:28:02
[12/16 14:53:43 d2.evaluation.evaluator]: Inference done 519/2530. 0.6490 s / img. ETA=0:28:03
[12/16 14:53:49 d2.evaluation.evaluator]: Inference done 524/2530. 0.6532 s / img. ETA=0:28:05
[12/16 14:53:54 d2.evaluation.evaluator]: Inference done 528/2530. 0.6575 s / img. ETA=0:28:09
[12/16 14:53:59 d2.evaluation.evaluator]: Inference done 532/2530. 0.6621 s / img. ETA=0:28:13
File "tools/train_net.py", line 108, in <module>
args=(args,),
File "/home/nvidia/detectron2/detectron2/engine/launch.py", line 62, in launch
main_func(*args)
File "tools/train_net.py", line 91, in main
res = Trainer.test(cfg, model)
File "tools/train_net.py", line 60, in test
results_i = inference_on_dataset(model, data_loader, evaluator)
File "/home/nvidia/detectron2/detectron2/evaluation/evaluator.py", line 141, in inference_on_dataset
outputs = model(inputs)
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/nn/modules/module.py", line 727, in _call_impl
result = self.forward(*input, **kwargs)
File "/home/nvidia/detectron2/detectron2/modeling/meta_arch/rcnn.py", line 149, in forward
return self.inference(batched_inputs)
File "/home/nvidia/detectron2/detectron2/modeling/meta_arch/rcnn.py", line 207, in inference
proposals, _ = self.proposal_generator(images, features, None)
File "/home/nvidia/detectron2/detectron2/modeling/proposal_generator/rpn.py", line 449, in forward
anchors, pred_objectness_logits, pred_anchor_deltas, images.image_sizes
File "/home/nvidia/detectron2/detectron2/modeling/proposal_generator/rpn.py", line 482, in predict_proposals
self.training,
File "/home/nvidia/detectron2/detectron2/modeling/proposal_generator/proposal_utils.py", line 104, in find_top_rpn_proposals
keep = batched_nms(boxes.tensor, scores_per_img, lvl, nms_thresh)
File "/home/nvidia/detectron2/detectron2/layers/nms.py", line 21, in batched_nms
return box_ops.batched_nms(boxes.float(), scores, idxs, iou_threshold)
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/jit/_trace.py", line 1100, in wrapper
return fn(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/torchvision-0.8.0a0+45f960c-py3.6-linux-aarch64.egg/torchvision/ops/boxes.py", line 88, in batched_nms
keep = nms(boxes_for_nms, scores, iou_threshold)
File "/usr/local/lib/python3.6/dist-packages/torchvision-0.8.0a0+45f960c-py3.6-linux-aarch64.egg/torchvision/ops/boxes.py", line 42, in nms
return torch.ops.torchvision.nms(boxes, scores, iou_threshold)
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/utils/data/_utils/signal_handling.py", line 66, in handler
_error_if_any_worker_fails()
RuntimeError: DataLoader worker (pid 19139) is killed by signal: Killed.
