Description
I am trying to install tensorrt on my Jetson AGX Orin. For that, I am following the Installation guide.
When trying to execute:
python3 -m pip install --upgrade tensorrt
I get the following output:
Looking in indexes: https://pypi.org/simple, https://pypi.ngc.nvidia.com
Requirement already satisfied: tensorrt in /usr/lib/python3.8/dist-packages (8.5.2.2)
Collecting tensorrt
Downloading tensorrt-8.6.1.post1.tar.gz (18 kB)
Preparing metadata (setup.py) ... done
Building wheels for collected packages: tensorrt
Building wheel for tensorrt (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [58 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib
creating build/lib/tensorrt
copying tensorrt/__init__.py -> build/lib/tensorrt
running egg_info
writing tensorrt.egg-info/PKG-INFO
writing dependency_links to tensorrt.egg-info/dependency_links.txt
writing requirements to tensorrt.egg-info/requires.txt
writing top-level names to tensorrt.egg-info/top_level.txt
reading manifest file 'tensorrt.egg-info/SOURCES.txt'
adding license file 'LICENSE.txt'
writing manifest file 'tensorrt.egg-info/SOURCES.txt'
installing to build/bdist.linux-aarch64/wheel
running install
Looking in indexes: https://pypi.org/simple, https://pypi.ngc.nvidia.com, https://pypi.nvidia.com
ERROR: Could not find a version that satisfies the requirement tensorrt_libs==8.6.1 (from versions: 9.0.0.post11.dev1, 9.0.0.post12.dev1, 9.0.1.post11.dev4, 9.0.1.post12.dev4, 9.1.0.post11.dev4, 9.1.0.post12.dev4)
ERROR: No matching distribution found for tensorrt_libs==8.6.1
File "/tmp/pip-install-b5g5dsev/tensorrt_99bbf7afbc544d02bc794b327cecbd48/setup.py", line 40, in run_pip_command
return call_func([sys.executable, "-m", "pip"] + args, env=env)
File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/home/orin/venv/bin/python3', '-m', 'pip', 'install', '--extra-index-url', 'https://pypi.nvidia.com', 'tensorrt_libs==8.6.1', 'tensorrt_bindings==8.6.1']' returned non-zero exit status 1.
During handling of the above exception, another exception occurred:
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/tmp/pip-install-b5g5dsev/tensorrt_99bbf7afbc544d02bc794b327cecbd48/setup.py", line 110, in <module>
setup(
File "/home/orin/venv/lib/python3.8/site-packages/setuptools/__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.8/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.8/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.8/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/home/orin/venv/lib/python3.8/site-packages/wheel/bdist_wheel.py", line 399, in run
self.run_command("install")
File "/usr/lib/python3.8/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/tmp/pip-install-b5g5dsev/tensorrt_99bbf7afbc544d02bc794b327cecbd48/setup.py", line 62, in run
run_pip_command(
File "/tmp/pip-install-b5g5dsev/tensorrt_99bbf7afbc544d02bc794b327cecbd48/setup.py", line 56, in run_pip_command
return call_func([pip_path] + args, env=env)
subprocess.CalledProcessError: Command '['/home/orin/venv/bin/pip', 'install', '--extra-index-url', 'https://pypi.nvidia.com', 'tensorrt_libs==8.6.1', 'tensorrt_bindings==8.6.1']' returned non-zero exit status 1.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for tensorrt
Running setup.py clean for tensorrt
Failed to build tensorrt
ERROR: Could not build wheels for tensorrt, which is required to install pyproject.toml-based projects
I have already tried to solve it following these instructions: Tensorrt not installing with pip. I created a virtual environment as indicated, but it doesn’t solve the issue.
Environment
TensorRT Version: 8.5.2
CUDA Version: 11.4
Operating System + Version: Jetson 5.1.2
Python Version (if applicable): 3.8
