Failed call to cuInit: CUDA_ERROR_NO_DEVICE: no CUDA-capable device is detected
Hello! I tried to train custom YOLO model for my project.
Here is my environment
tensorflow-gpu 2.0
CUDA 10.0
cuDNN 7.4.2
GTX 1070
VS2017
I executed train file, but got this error.
> 2020-09-04 22:57:09.765952: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library cudart64_100.dll
> 2020-09-04 22:57:12.180849: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library nvcuda.dll
> 2020-09-04 22:57:12.207369: E tensorflow/stream_executor/cuda/cuda_driver.cc:318] failed call to cuInit: CUDA_ERROR_NO_DEVICE: no CUDA-capable device is detected
I use windows 10 and anaconda virtual environment.
I set CUDA_VISIBLE_DEVICES=‘0’.
When I load gpu list at python IDLE on virtual environment, gpu list is successfully loaded.
But still got same error.
Here is also nvidia-smi result. I don’t understand why compute processes are not supported.
Fri Sep 04 23:16:59 2020
    | NVIDIA-SMI 432.00       Driver Version: 452.06       CUDA Version: 11.0     |
    | GPU  Name            TCC/WDDM | Bus-Id        Disp.A | Volatile Uncorr. ECC |
    | Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
    |   0  GeForce GTX 1070   WDDM  | 00000000:09:00.0  On |                  N/A |
    |  0%   48C    P0    36W /  N/A |    779MiB /  8192MiB |      0%      Default |
    | Processes:                                                       GPU Memory |
    |  GPU       PID   Type   Process name                             Usage      |
    |    0                    Not Supported                                       |
Help me please…
Did you solve it?
