I’ve recently upgraded to latest kernel 6.0.2-76060002-generic and Nvidia driver 515.65.01-1pop0~1666367711~22.04~b8c0232 and I’m seeing many errors from journalctl -p 3 -r:
Oct 27 09:34:00 pop-os gdm-launch-environment][1478]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 27 09:34:00 pop-os gnome-session-binary[1601]: GLib-CRITICAL: g_hash_table_foreach_remove_or_steal: assertion 'version == hash_table->version' failed
Oct 27 09:33:59 pop-os kernel: [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00002600] Failed to grab modeset ownership
Oct 27 09:33:58 pop-os systemd[7190]: Failed to start Application launched by gnome-session-binary.
Oct 27 09:33:56 pop-os systemd[7190]: Failed to start Application launched by gnome-session-binary.
Oct 27 09:33:55 pop-os dbus-broker-launch[7215]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.freedesktop.FileManager1.service'
Oct 27 09:33:54 pop-os gdm-password][5016]: gkr-pam: unable to locate daemon control file
Oct 27 09:30:41 pop-os gnome-session-binary[1601]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
Oct 27 09:30:40 pop-os dbus-broker-launch[1509]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.freedesktop.FileManager1.service'
Oct 27 09:30:39 pop-os systemd[1]: Failed to start LSB: OpenIPMI Driver init script.
Oct 27 09:30:38 pop-os kernel:
Oct 27 09:30:38 pop-os kernel: blacklist: Problem blacklisting hash (-13)
I want to highlight the error:
Does anyone know what could be causing it and if there is a way to fix that?
I’m on Pop_OS! 22.04 and have a “ASUS Phoenix GeForce® GTX 1660 OC edition 6GB GDDR5 - PH-GTX1660-O6G” card.
$ sudo dmesg | grep -i -e "nv-" -e "nvidia" -e "drm"
[ 5.852275] systemd[1]: Finished Load Kernel Module drm.
[ 6.313970] nvidia: module license 'NVIDIA' taints kernel.
[ 6.417301] nvidia-nvlink: Nvlink Core is being initialized, major device number 236
[ 6.418202] nvidia 0000:26:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 6.422032] audit: type=1400 audit(1666855838.722:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=885 comm="apparmor_parser"
[ 6.422035] audit: type=1400 audit(1666855838.722:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=885 comm="apparmor_parser"
[ 6.461422] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
[ 6.503688] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 515.65.01 Wed Jul 20 13:43:59 UTC 2022
[ 6.505726] [drm] [nvidia-drm] [GPU ID 0x00002600] Loading driver
[ 6.512218] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card1/input3
[ 6.512276] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card1/input4
[ 6.512314] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card1/input5
[ 6.512369] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card1/input6
[ 6.512415] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card1/input7
[ 6.512464] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card1/input8
[ 7.464161] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:26:00.0 on minor 0
[ 7.472261] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 7.508096] nvidia-uvm: Loaded the UVM driver, major device number 234.
[ 207.199101] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00002600] Failed to grab modeset ownership
$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
GCC version: gcc version 11.3.0 (Ubuntu 11.3.0-1ubuntu1~22.04)
$ dpkg -l | grep nvidia
ii libnvidia-cfg1-515:amd64 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-515 515.65.01-1pop0~1666367711~22.04~b8c0232 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-440:amd64 455.23-0pop1~1601997893~20.04~a506bc9 amd64 Transitional package for libnvidia-compute-455
rc libnvidia-compute-455:amd64 460.32.03-1pop0~1611601564~20.10~11a4029 amd64 Transitional package for libnvidia-compute-460
rc libnvidia-compute-460:amd64 465.31-1pop0~1623777959~20.10~a3ca7f3 amd64 Transitional package for libnvidia-compute-465
rc libnvidia-compute-465:amd64 470.57.02-1pop0~1627044105~21.04~f9815ed amd64 Transitional package for libnvidia-compute-470
rc libnvidia-compute-470:amd64 510.54-1pop0~1645544462~21.10~e35d257 amd64 Transitional package for libnvidia-compute-510
rc libnvidia-compute-510:amd64 510.85.02-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-515:amd64 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA libcompute package
ii libnvidia-compute-515:i386 515.65.01-1pop0~1666367711~22.04~b8c0232 i386 NVIDIA libcompute package
ii libnvidia-container-tools 1.12.0~rc.1-1 amd64 NVIDIA container runtime library (command-line tools)
ii libnvidia-container1:amd64 1.12.0~rc.1-1 amd64 NVIDIA container runtime library
ii libnvidia-decode-515:amd64 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-515:i386 515.65.01-1pop0~1666367711~22.04~b8c0232 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.9-1.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-515:amd64 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-515:i386 515.65.01-1pop0~1666367711~22.04~b8c0232 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-515:amd64 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-515:amd64 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-515:i386 515.65.01-1pop0~1666367711~22.04~b8c0232 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-515:amd64 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-515:i386 515.65.01-1pop0~1666367711~22.04~b8c0232 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc nvidia-compute-utils-510 510.85.02-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-515 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA compute utilities
ii nvidia-container-toolkit 1.12.0~rc.1-1 amd64 NVIDIA Container toolkit
ii nvidia-container-toolkit-base 1.12.0~rc.1-1 amd64 NVIDIA Container Toolkit Base
rc nvidia-dkms-510 510.85.02-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-dkms-515 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA DKMS package
ii nvidia-docker2 2.11.0-1 all nvidia-docker CLI wrapper
ii nvidia-driver-515 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA driver metapackage
rc nvidia-kernel-common-510 510.85.02-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-515 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-515 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA kernel source package
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-515 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-515 515.65.01-1pop0~1666367711~22.04~b8c0232 amd64 NVIDIA binary Xorg driver
edit:
Same issues with kernel 5.19.16-76051916-generic.
