nvidia-smi returns this error, and I have already autoremove the nvidia-driver-440 into nvidia-driver-455, and it still return like that and my pytorch can not detect the gpu there. Please tell me how to fix it?
The command:
sudo lspci -v | grep VGA
returns
01:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A] (rev a1) (prog-if 00 [VGA controller])
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Hi, i have the same problem, help me plz
lsb_release -a
Summary
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.5 LTS
Release: 18.04
Codename: bionic
uname -a
Linux ubuntu 4.15.0-129-generic #132-Ubuntu SMP Thu Dec 10 14:02:26 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
sudo nvidia-settings
wokring fine …
nvidia-smi
Failed to initialize NVML: Driver/library version mismatch
sudo prime-select query
nvidia
lspci
Summary
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 09)
00:04.0 Signal processing controller: Intel Corporation Haswell-ULT Thermal Subsystem (rev 09)
00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4)
00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4)
00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4)
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
00:1f.6 Signal processing controller: Intel Corporation 8 Series Thermal (rev 04)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
03:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
04:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 745M] (rev a1)
lspci | grep “VGA”
lshw
Summary
*-display
description: VGA compatible controller
product: Haswell-ULT Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:44 memory:f7400000-f77fffff memory:d0000000-dfffffff ioport:f000(size=64) memory:c0000-dffff
*-display
description: 3D controller
product: GK107M [GeForce GT 745M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:04:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:45 memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:d000(size=128) memory:f7000000-f707ffffHi, i have same problem, help me plz
dpkg -l | grep -i nvidia
Summary
ii bbswitch-dkms 0.8-4ubuntu1 amd64 Interface for toggling the power on NVIDIA Optimus video cards
ii libnvidia-cfg1-390:amd64 390.141-0ubuntu0.18.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-390 390.141-0ubuntu0.18.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-390:amd64 390.141-0ubuntu0.18.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-390:i386 390.141-0ubuntu0.18.04.1 i386 NVIDIA libcompute package
rc libnvidia-compute-415:amd64 415.27-0ubuntu0~gpu18.04.2 amd64 NVIDIA libcompute package
ii libnvidia-decode-390:amd64 390.141-0ubuntu0.18.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-390:i386 390.141-0ubuntu0.18.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-390:amd64 390.141-0ubuntu0.18.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-390:i386 390.141-0ubuntu0.18.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-fbc1-390:amd64 390.141-0ubuntu0.18.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-390:amd64 390.141-0ubuntu0.18.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-390:i386 390.141-0ubuntu0.18.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-390:amd64 390.141-0ubuntu0.18.04.1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii nvidia-compute-utils-390 390.141-0ubuntu0.18.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-390 390.141-0ubuntu0.18.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-390 390.141-0ubuntu0.18.04.1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-390 390.141-0ubuntu0.18.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-390 390.141-0ubuntu0.18.04.1 amd64 NVIDIA kernel source package
ii nvidia-modprobe 384.111-2 amd64 utility to load NVIDIA kernel modules and create device nodes
ii nvidia-prime 0.8.8.2 all Tools to enable NVIDIA's Prime
ii nvidia-settings 440.82-0ubuntu0.18.04.1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-390 390.141-0ubuntu0.18.04.1 amd64 NVIDIA driver support binaries
ii xserver-xorg-video-nvidia-390 390.141-0ubuntu0.18.04.1 amd64 NVIDIA binary Xorg driver
nvidia-bug-report.log.gz (109.9 KB)
You’re booting into an old kernel, so there’s a mismatch between X driver and kernel driver. Please hold down shift on boot so the grub menu shows up and select the correct kernel (4.15.0-132).
It is working, thank you very much
