I’m pretty new at this so please have patience :)
We have a 3 node VMware cluster running VMware 6.0U1a. We have just installed a Nvidia Grid K1 in one of our hosts.
The host is an IBM 3850 X6 and we have installed the card in slot 4 which is a PCIe x16 slot belonging to CPU3
I have followed the deployment guide and have changed the BIOS settings accordingly:
[b]* Memory Mapped Config Base memory window - changed from auto to 2 GB - (I think it supposed to be below 4 GB)
- 64-bit PCI Resource - changed from Enabled to Disabled[/b]
I have installed the Virtual GPU manager:
esxcli software vib list | grep -i nvidia
NVIDIA-vgx-VMware_ESXi_6.0_Host_Driver 346.42-1OEM.600.0.0.2159203 NVIDIA VMwareAccepted 2015-12-14
The module is loaded:
esxcfg-module -l | grep nvidia
nvidia 0 8420
When I run the nvidia-smi command:
nvidia-smi
Failed to initialize NVML: Unknown Error
Theres no output in the vmkernel.log:
cat /var/log/vmkernel.log | grep NVRM
[root@ESX-F-1:/var/log]
VMware doesn’t seem to be aware of the Nvidia card. It only finds the onboard graphics card:
lspci | grep -i display
0000:1b:00.0 Display controller: Matrox Electronics Systems Ltd. G200eR2
I have struggled with this issue quite some time now so I really hope you can help.
/Michael
