I have a docker image of Jetson nano base on nvcr.io/nvidia/l4t-ml:r32.7.1-py3 + an installation of TensorRT 8.2.1.9 (Cuda 10.2).
This docker image is executed on my PC (x64) using arm64 qemu virtualization + option --runtime nvidia when I launch the docker image.
When I compile/link my code with TensorRT libraries, I have this error :
/usr/bin/ld: warning: libnvdla_compiler.so, needed by /usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libnvmedia.so, needed by /usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so, not found (try using -rpath or -rpath-link)
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorUnlock'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaEglStreamProducerGetTensor'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorEglStreamConsumerCreate'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaSetCurrentLoadable'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaDataUnregister'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaGetNumOfOutputTensors'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorEglStreamProducerPostMetaData'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::createWisdom()'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaGetInputTensorDescriptor'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaLoadableCreate'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaEglStreamConsumerReleaseTensor'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::destroyWisdom(nvdla::IWisdom*)'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorLock'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorDestroy'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaGetMaxOutstandingTasks'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaLoadLoadable'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaEglStreamProducerPostTensor'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaGetOutputTensorDescriptor'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaDataRegister'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaEglStreamConsumerAcquireTensor'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaGetNumOfInputTensors'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorEglStreamConsumerAcquireMetaData'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDeviceDestroy'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaInit'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorEglStreamProducerCreate'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaAppendLoadable'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorEglStreamProducerDestroy'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaRemoveLoadable'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDeviceCreate'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::destroyNetwork(nvdla::INetwork*)'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorGetMetaData'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaSubmit'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaDestroy'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaCreate'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorCreate'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaGetNumEngines'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorEglStreamConsumerDestroy'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::createNetwork()'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaTensorGetStatus'
/usr/lib/gcc/aarch64-linux-gnu/8/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `NvMediaDlaLoadableDestroy'
collect2: error: ld returned 1 exit status
Here the result of ldd on libnvinfer.so
root@7d277e11be1f:/# ldd /usr/lib/aarch64-linux-gnu/libnvinfer.so
librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x000000400b7b7000)
libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x000000400b7ce000)
libnvdla_compiler.so => not found
libEGL.so.1 => /usr/lib/aarch64-linux-gnu/libEGL.so.1 (0x000000400b7e3000)
libnvmedia.so => not found
libstdc++.so.6 => /usr/lib/aarch64-linux-gnu/libstdc++.so.6 (0x000000400b804000)
libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x000000400b99a000)
libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x000000400ba53000)
libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x000000400ba77000)
/lib/ld-linux-aarch64.so.1 (0x0000004000000000)
libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x000000400bbd0000)
libGLdispatch.so.0 => /usr/lib/aarch64-linux-gnu/libGLdispatch.so.0 (0x000000400bbfc000)
The reason if that the file libnvmedia.so is empty.
I see on other forum post that it could be due to the fact that this library is link to the host.
Could you help me to solve that problem?
I do not see that I have to change to my docker image to be able to compile for TensorRT (not that I cannot execute that docker image directly on the Jetson Nano device (version 32.7.1) because there is not enough free space on the SD card.
