Failed to simpleP2P
I’m trying to check p2p access (GPU ↔ GPU) via PCIe.
But, NVIDIA’s sample code don’t work on my enviroment.
Item Content
MB ASUS PROART Z790-CREATOR WIFI (DDR5)
OS Ubuntu 22.04.4 LTS
CPU 13th Gen Intel(R) Core™ i9-13900
GPU0 NVIDIA RTX 6000 Ada Generation
GPU1 NVIDIA RTX 4000 SFF Ada Generation
NVIDIA Driver Driver Version: 555.42.02 (Open)
NVCC V12.5.40
$ make run
./simpleP2P
[./simpleP2P] - Starting...
Checking for multiple GPUs...
CUDA-capable device count: 2
Checking GPU(s) for support of peer to peer memory access...
> Peer access from NVIDIA RTX 6000 Ada Generation (GPU0) -> NVIDIA RTX 4000 SFF Ada Generation (GPU1) : No
> Peer access from NVIDIA RTX 4000 SFF Ada Generation (GPU1) -> NVIDIA RTX 6000 Ada Generation (GPU0) : No
Two or more GPUs with Peer-to-Peer access capability are required for ./simpleP2P.
Peer to Peer access is not available amongst GPUs in the system, waiving test.
make: *** [Makefile:373: run] Error 2
So I checked topology of GPUs and find “NS”.
There are many topics related to CNS, but I couldn’t find any topics related to NS.
Does anyone know the cause of this?
$ nvidia-smi topo -m
        GPU0    GPU1    CPU Affinity    NUMA Affinity   GPU NUMA ID
GPU0     X      PHB     0-15    0               N/A
GPU1    PHB      X      0-15    0               N/A
Legend:
  X    = Self
  SYS  = Connection traversing PCIe as well as the SMP interconnect between NUMA nodes (e.g., QPI/UPI)
  NODE = Connection traversing PCIe as well as the interconnect between PCIe Host Bridges within a NUMA node
  PHB  = Connection traversing PCIe as well as a PCIe Host Bridge (typically the CPU)
  PXB  = Connection traversing multiple PCIe bridges (without traversing the PCIe Host Bridge)
  PIX  = Connection traversing at most a single PCIe bridge
  NV#  = Connection traversing a bonded set of # NVLinks
$ nvidia-smi topo -p2p r
        GPU0    GPU1
 GPU0   X       NS
 GPU1   NS      X
Legend:
  X    = Self
  OK   = Status Ok
  CNS  = Chipset not supported
  GNS  = GPU not supported
  TNS  = Topology not supported
  NS   = Not supported
  U    = Unknown
More infos
nvidia-smi
$ nvidia-smi -a
==============NVSMI LOG==============
Timestamp                                 : Mon Aug 19 20:41:03 2024
Driver Version                            : 555.42.02
CUDA Version                              : 12.5
Attached GPUs                             : 2
GPU 00000000:01:00.0
    Product Name                          : NVIDIA RTX 6000 Ada Generation
    Product Brand                         : NVIDIA RTX
    Product Architecture                  : Ada Lovelace
    Display Mode                          : Enabled
    Display Active                        : Disabled
    Persistence Mode                      : Disabled
    Addressing Mode                       : None
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : 1322123003492
    GPU UUID                              : GPU-6a8f4713-9e95-c4df-e5a6-ce2ea034111e
    Minor Number                          : 0
    VBIOS Version                         : 95.02.59.00.09
    MultiGPU Board                        : No
    Board ID                              : 0x100
    Board Part Number                     : 900-5G133-2250-000
    GPU Part Number                       : 26B1-870-A1
    FRU Part Number                       : N/A
    Module ID                             : 1
    Inforom Version
        Image Version                     : G133.0510.00.02
        OEM Object                        : 2.1
        ECC Object                        : 6.16
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : N/A
        Latest Duration                   : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Virtualization Mode
        Virtualization Mode               : None
        Host VGPU Mode                    : N/A
        vGPU Heterogeneous Mode           : N/A
    GPU Reset Status
        Reset Required                    : No
        Drain and Reset Recommended       : N/A
    GSP Firmware Version                  : 555.42.02
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x01
        Device                            : 0x00
        Domain                            : 0x0000
        Base Classcode                    : 0x3
        Sub Classcode                     : 0x0
        Device Id                         : 0x26B110DE
        Bus Id                            : 00000000:01:00.0
        Sub System Id                     : 0x16A110DE
        GPU Link Info
            PCIe Generation
                Max                       : 4
                Current                   : 1
                Device Current            : 1
                Device Max                : 4
                Host Max                  : 4
            Link Width
                Max                       : 16x
                Current                   : 8x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 0 KB/s
        Rx Throughput                     : 0 KB/s
        Atomic Caps Inbound               : N/A
        Atomic Caps Outbound              : N/A
    Fan Speed                             : 30 %
    Performance State                     : P8
    Clocks Event Reasons
        Idle                              : Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    Sparse Operation Mode                 : N/A
    FB Memory Usage
        Total                             : 49140 MiB
        Reserved                          : 603 MiB
        Used                              : 2 MiB
        Free                              : 48536 MiB
    BAR1 Memory Usage
        Total                             : 65536 MiB
        Used                              : 11 MiB
        Free                              : 65525 MiB
    Conf Compute Protected Memory Usage
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Compute Mode                          : Default
    Utilization
        Gpu                               : 0 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
            SRAM Correctable              : N/A
            SRAM Uncorrectable Parity     : N/A
            SRAM Uncorrectable SEC-DED    : N/A
            DRAM Correctable              : N/A
            DRAM Uncorrectable            : N/A
        Aggregate
            SRAM Threshold Exceeded       : N/A
        Aggregate Uncorrectable SRAM Sources
            SRAM L2                       : N/A
            SRAM SM                       : N/A
            SRAM Microcontroller          : N/A
            SRAM PCIE                     : N/A
            SRAM Other                    : N/A
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows
        Correctable Error                 : 0
        Uncorrectable Error               : 0
        Pending                           : No
        Remapping Failure Occurred        : No
        Bank Remap Availability Histogram
            Max                           : 192 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 45 C
        GPU T.Limit Temp                  : 45 C
        GPU Shutdown T.Limit Temp         : -7 C
        GPU Slowdown T.Limit Temp         : -2 C
        GPU Max Operating T.Limit Temp    : 0 C
        GPU Target Temperature            : 85 C
        Memory Current Temp               : N/A
        Memory Max Operating T.Limit Temp : N/A
    GPU Power Readings
        Power Draw                        : 24.64 W
        Current Power Limit               : 300.00 W
        Requested Power Limit             : 300.00 W
        Default Power Limit               : 300.00 W
        Min Power Limit                   : 100.00 W
        Max Power Limit                   : 300.00 W
    GPU Memory Power Readings
        Power Draw                        : N/A
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Clocks
        Graphics                          : 210 MHz
        SM                                : 210 MHz
        Memory                            : 405 MHz
        Video                             : 1185 MHz
    Applications Clocks
        Graphics                          : 2505 MHz
        Memory                            : 10001 MHz
    Default Applications Clocks
        Graphics                          : 2505 MHz
        Memory                            : 10001 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 3105 MHz
        SM                                : 3105 MHz
        Memory                            : 10001 MHz
        Video                             : 2415 MHz
    Max Customer Boost Clocks
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : 910.000 mV
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
    Processes                             : None
    Capabilities
        EGM                               : disabled
GPU 00000000:02:00.0
    Product Name                          : NVIDIA RTX 4000 SFF Ada Generation
    Display Mode                          : Disabled
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : 1321423017491
    GPU UUID                              : GPU-128f0adb-018e-b8a9-29a2-cdbad6f96dec
    Minor Number                          : 1
    VBIOS Version                         : 95.04.46.00.08
    MultiGPU Board                        : No
    Board ID                              : 0x200
    Board Part Number                     : 900-5G192-2571-000
    GPU Part Number                       : 27B0-850-A1
    Module ID                             : 1
    Inforom Version
        Image Version                     : G192.0550.00.02
        OEM Object                        : 2.1
        ECC Object                        : 6.16
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0x02
        Device                            : 0x00
        Domain                            : 0x0000
        Sub Classcode                     : 0x0
        Device Id                         : 0x27B010DE
        Bus Id                            : 00000000:02:00.0
        Sub System Id                     : 0x16FA10DE
        GPU Link Info
            PCIe Generation
                Max                       : 4
                Current                   : 1
                Device Current            : 1
                Device Max                : 4
                Host Max                  : 4
            Link Width
                Max                       : 16x
                Current                   : 8x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Tx Throughput                     : 1 KB/s
    Fan Speed                             : 30 %
        Idle                              : Active
    FB Memory Usage
        Total                             : 20475 MiB
        Reserved                          : 420 MiB
        Used                              : 2 MiB
        Free                              : 20055 MiB
    BAR1 Memory Usage
        Total                             : 32768 MiB
        Used                              : 2 MiB
        Free                              : 32766 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 0 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
        Aggregate
            SRAM L2                       : N/A
            SRAM SM                       : N/A
            SRAM PCIE                     : N/A
            SRAM Other                    : N/A
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 96 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 37 C
        GPU T.Limit Temp                  : 47 C
        GPU Target Temperature            : 88 C
    GPU Power Readings
        Power Draw                        : 6.57 W
        Current Power Limit               : 70.00 W
        Requested Power Limit             : 70.00 W
        Default Power Limit               : 70.00 W
        Min Power Limit                   : 30.00 W
        Max Power Limit                   : 70.00 W
        Power Draw                        : N/A
        Power Draw                        : N/A
    Clocks
        Graphics                          : 210 MHz
        SM                                : 210 MHz
        Memory                            : 405 MHz
        Video                             : 765 MHz
    Applications Clocks
        Graphics                          : 1560 MHz
        Memory                            : 7001 MHz
        Graphics                          : 1560 MHz
        Memory                            : 7001 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 3105 MHz
        SM                                : 3105 MHz
        Memory                            : 7001 MHz
        Video                             : 2415 MHz
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
    Voltage
        Graphics                          : 650.000 mV
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
    Processes                             : None
    Capabilities
        EGM                               : disabled
P2P requires, among other things identical GPUs. Yours are not identical. In addition, in some cases, for some GPUs, P2P requires installation of a NVLink bridge. And there exist GPUs for which P2P is simply not supported.
NS: Not supported.
If you desire or require P2P support, you should make that a condition of system purchase, before purchasing the system from a qualified vendor.
Thank you replying and sorry for delaying to reply.
It is information what I want to know.
