My device is jetson agx orin devkit with nv_tegra_release version # R34.1.1, and I want to clone a system.img.
My host machine system is Ubuntu20.04 LTS which is installed with Jetson_Linux_R34.1.1_aarch64.tbz2 and Tegra_Linux_Sample-Root-Filesystem_R34.1.1_aarch64.tbz2.
Clone command is “sudo ./flash.sh -r -k APP -G system.img jetson-agx-orin-devkit mmcblk0p1”, and I get the system.img.raw, but at the end of the flashing process , it prompt “size of system.img.raw is not mulple of 4096.”, the system.img is 0kb. The size of system.img.raw is 62225330688(is not mulple of 4096). And in the attachment you can see the log info. log.txt (52.0 KB)
what’s the issue here?
In addition, I want to ask if only use the system.img.raw file can restore the jetson system?
If I re-flash the device with this new patch, the application I have developped with nv_tegra_release version # R34.1.1 can still work in jetson agx orin?
I need to confirm with you again that you mean I have to re-flash the jetson agx orin new jetpack version “JP5.1.2(R35.4.1)” and my application based on pytorch framework can still work?
Then I can clone the new installed system?
Use whatever way (git patch/manual copy) to replace the content of Linux_for_Tegra/rootfs/usr/lib/nvidia/resizefs/nvresizefs.sh with the one in the link I posted earlier.
I replaced the file “Linux_for_Tegra/rootfs/usr/lib/nvidia/resizefs/nvresizefs.sh” with version 35.4.1 but the system.img is still 0kb.
Can you give a more reasonable solution?
