• Hardware Platform (Jetson / GPU) GPU RTX3090
• DeepStream Version 5.1
• TensorRT Version 7.2.2.3
• NVIDIA GPU Driver Version (valid for GPU only) 470.63 cuda11.1
I run deepstream-test3.py. My pipeline has detector and classifier, I classify detected boxes from detector(first detect then classify). I encountered this error while frame has two or more objects , but if there is one object in frame it works fine. Then I turned off classifier model and detector works fine with more objects(detects objects without any problem). Classifer engine and Detector engine have same batch_size.
0:02:34.202632301 269 0x2fc1050 WARN nvinfer gstnvinfer.cpp:1277:convert_batch_and_push_to_input_thread: error: NvBufSurfTransform failed with error -3 while converting buffer
Error: gst-stream-error-quark: NvBufSurfTransform failed with error -3 while converting buffer (1): gstnvinfer.cpp(1277): convert_batch_and_push_to_input_thread (): /GstPipeline:pipeline0/GstNvInfer:secondary2-nvinference-engine
