Fast type casting (short -> float)
OK so I’ve got a buffer of short data that I’m trying to do some stuff with, things like transpose, filter, transpose again, etc. Does anyone know a good way to do a fast type conversion between a short buffer and a float buffer on the GPU? I tried something like this:
typedef struct dual_short {
     short a;
     short b;
} dual_short;
typedef struct dual_float {
     float a;
     float b;
} dual_float;
__global__ void convert_input(short* inp_buffer, float* out_buffer, int width, int height) {
     dual_short* ds_ptr = (dual_short*)inp_buffer;
     dual_float* df_ptr = (dual_float*)out_buffer;
    unsigned int xIndex = 2*(blockIdx.x * CONV_BLOCK_DIM + threadIdx.x);
     unsigned int yIndex =    blockIdx.y * CONV_BLOCK_DIM + threadIdx.y;
     if ((xIndex < width) && (yIndex < height)) {
          unsigned int index_in = yIndex * width/2 + xIndex;
         // Convert two shorts at a time
          dual_short temp_ds = ds_ptr[index_in];
          dual_float temp_df;
               temp_df.a = (float)temp_ds.a;
               temp_df.b = (float)temp_ds.b;
         df_ptr[index_in] = temp_df;
But the visual profiler is still reporting it as un-coalesced. Note the dual_float type is there so I can try to coalesce on the 64-bit type. CONV_BLOCK_DIM = 16
Aha, got it working, shouldn’t have had that factor of two on the xIndex calculation:
    unsigned int xIndex = blockIdx.x * CONV_BLOCK_DIM + threadIdx.x;
By luck you can do better… The hardware supports FREE short → float conversion on read, useful in graphics texture maps where you have a fixed-point image intensity.
Look at section 4.3.4 in the programming guide to see how to set up a texture that will let you stream in your shorts and convert to floats.
You’ll be 100% memory bandwidth limited of course. To be honest you would be even using the (float) conversion directly.
But you might also ask why you’re converting to a float. If its for some later calculation that uses floats, you might use the free texture conversion when you read the data.
