I know this sounds a bit stupid - but I dont get any performance boost from my linux GTX480 over my Windows GTX280. Both environments are 64bit.
The kernel is ~ 50% memory bound and 50% compute bound.
I tried the following things:
Replace texture accesses with global access.
Configure the main kernel to 16KB shared mem and 48KB L1 (or vice versa)
Increased the amount of threads per block from 64 to 128,256,512,1024.
The kernel looks roughly like this:
__inline__ __device__ void CalcTraceData( unsigned int iTraceChunk, unsigned int iTraceIndex, unsigned short iTimeIndex,
short Nb, short numMoveSamples, float w2, int InputTracePos,
float2 *pDataInput,
float &f1, float &f2, float &f3, float &f4 )
if ( ( iTimeIndex >= Nb ) && ( iTimeIndex < numMoveSamples ) )
float w1 = 1.f - w2;
float2 fCurrentTimeValues = tex1Dfetch( texInput, iInputPos );
float2 fNextTimeValues = tex1Dfetch( texInput, iInputPos + 1 );
float fPhaseValW1 = fCurrentTimeValues.x * w1;
float fPhaseValPlusOneW2 = fNextTimeValues.x * w2;
f1 += fPhaseValW1 + fPhaseValPlusOneW2;
f2 += fCurrentTimeValues.x * fPhaseValW1 + fNextTimeValues.x * fPhaseValPlusOneW2;
f3 += fCurrentTimeValues.y * w1 + fNextTimeValues.y * w2;
f4++;
// Main kernel function
__shared__ short2 smPositions[ ENGINE_BLOCK_THREAD_SIZE ];
__shared__ float smw2[ ENGINE_BLOCK_THREAD_SIZE ];
__shared__ int smInputTracePos[ ENGINE_BLOCK_THREAD_SIZE ];
// Loop is manually unrolled 16 times...
for( int iTraceIndex = 0; iTraceIndex < ENGINE_BLOCK_THREAD_SIZE; iTraceIndex ++ )
CalcTraceData( iTraceChunk, iTraceIndex, iTimeIndex,
smPositions[ iTraceIndex ].x, smPositions[ iTraceIndex ].y, smw2[ iTraceIndex ], smInputTracePos[ iTraceIndex ], pDataInput,
fTraceOutPhase, fTraceOutPhase2, fTraceOutStack, fFold );
Some of the changes yield even worse performance than the GTX280 and the others gave the same performance.
Here is the command line I’ve used (for a block size of 128):
/usr/local/cuda/bin/nvcc --ptxas-options="-v " -gencode=arch=compute_20,code=“sm_20,compute_20” -maxrregcount=30 --compiler-options="-fno-strict-aliasing -fPIC" -I ~build/NVIDIA_CUDA_SDK/common/inc/ -I /home/build/build -I /home/build/build -I. -I /usr/local/include -I /usr/include -I /usr/local/cuda/include -O3 -DUNIX -o Engine/GPU/Engine.o -c Engine/GPU/Engine.cu
ptxas info : Compiling entry function '_Z15CalculateEngineILb0EEvjjjjjjP23ramsPjS2_PiPfS3_P6flo
at2S4_S4_S4_S4_’ for ‘sm_20’
ptxas info : Used 30 registers, 1612+0 bytes smem, 144 bytes cmem[0], 27368 bytes cmem[2], 8 bytes cmem[16]
g++ -L/usr/local/lib64 -DTIXML_USE_STL -pthread -L. -L /home/build/build/lib64 -L /home/build/build/lib64 -L /usr/local/cuda/lib64 -L ~build/NVIDIA_CUDA_SDK/lib -L ~build/NVIDIA_CUDA_SDK/common/lib/linux/ -lcudart -lcutil -shared -o libEngineGNU64.so -DTIXML_USE_STL -I /home/build/build -I /home/build/build -I. -I /usr/local/include -I /usr/include -I /usr/local/cuda/include -I ~build/NVIDIA_CUDA_SDK/common/inc/ -O3 -fomit-frame-pointer -falign-functions=16 -fprefetch-loop-arrays -fpeel-loops -funswitch-loops -ftree-vectorize -fPIC -m64 -fargument-noalias -funroll-loops Engine/Engine.o
EDIT: It seems that with SM2.0 I get twice the register usage than in 2.3, why is that? dual dispatcher? is that ok?
If I remove the maxregcount (which was there in the first place for another kernel) I get that the kernel uses 32 registers where
in 2.3 it only used 16.
Any ideas/assistance would be highly appreciated.
Eyal
