fetch texture memory error!
I tried to use texture memory to accelerate my application and wrote a piece of code as below:
----------------------file_name: main.cu------------------------------------------
#include <stdio.h>
texture<int, 1>ref;
__global__ void fetch_kernel()
	int val = tex1Dfetch(ref, 0);
	printf("val = %d.", val);
int main(int argc, char *argv[])
	int in[2]={1,2};
	int *d_in;
	cudaMalloc((void **)&d_in, 2 * sizeof(int));
	cudaMemcpy(d_in, in, 2 * sizeof(int), cudaMemcpyHostToDevice);
	cudaBindTexture(0, ref, d_in, 2 * sizeof(int));
	fetch_kernel<<<1, 1>>>();
	cudaDeviceSynchronize();
	cudaUnbindTexture(ref);
	return 0;
The output of this code is “val = 1.” The first element of array d_in was fetched.
And then, I restructured this code in three files as below:
------------------------kernel.h----------------------------------------
#ifndef KERNEL_H_
#define KERNEL_H_
texture<int, 1>ref;
global void fetch_kernel(int *d_in);
#endif /* KERNEL_H_ */
-----------------------kernel.cu-----------------------------
#include “kernel.h”
#include <stdio.h>
global void fetch_kernel()
printf(“val = %d.”, val);
-----------------------main.cu---------------------------------
#include “kernel.h”
int main(int argc, char *argv)
int in[2]={1,2};
int *d_in;
return 0;
The output of this code is “val = 0.” The first element of array d_in was not fetched correctly!!!
Why?? Thanks for your help.
I use SLES 11 SP2 with cuda 5.0 and Tesla S2050 GPU.
The code is compilered as below:
nvcc -c kernel.cu -arch=sm_20
nvcc -c main.cu -arch=sm_20
nvcc kernel.o main.o -o tex
Texture references in different compilation units are separate independent objects, even if they have the same name. I.e. they work as if they had a “static” storage-class specifier prepended.
Note that the code would even be illegal if textures followed the same linking rules as ordinary variables do, because then one of the definitions would need to declare the variable as “extern”.
