I am new to CUDA and so would really appreciate if someone could help me with this.
I need to implement the FFT in 3d in CUDA. Function below will be called by a Fortan program
extern “C” void tempfft_(int *n1, int *n2, int *n3,cufftComplex *data)
int Nx = *n1;
int Ny = *n2;
int Nz = *n3;
// Allocate device memory for the data
cufftComplex *d_data;
cudaMalloc((void**) &d_data, sizeof(cufftComplex)*Nx*Ny*Nz);
//Copy host memory to device
cudaMemcpy(d_data, data, Nx*Ny*Nz*sizeof(cufftComplex), cudaMemcpyHostToDevice);
//CUFFT plan
cufftHandle plan;
cufftPlan3d(&plan, NX, NY, NZ, CUFFT_C2C);
//FFT Execution
cufftExecC2C(plan, (cufftComplex *)d_data, (cufftComplex *)d_data, CUFFT_FORWARD);
//Copy result to the host
cudaMemcpy(data, d_data, Nx*Ny*Nz*sizeof(cufftComplex), cudaMemcpyDeviceToHost);
//Clear device memory
cufftDestroy(plan);
cudaFree(d_data);
return data;
My questions are:
a) Is the above code sufficient enough to find the FFT in 3D ? Or global and device needed ?
B) There is a sample simpleCUFFT defined in cuda sdk. It has whole bunch of functions defined like Paddata, Convolve etc etc. Are those functions needed in this program as well ?
Please neglect my ignorance in CUDA.
Thanks a lot.
-Shalini.
