Hello all,
Please, before I proceed, I am quiet new to programming. I have been working on a project where I utilize ONNX and TensorRT, however, I am getting an error:
FileNotFoundError: Could not find module ‘C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.7\bin\nvinfer.dll’ (or one of its dependencies). Try using the full path with constructor syntax.
Which means, the nvinfer.dll cannot be found in the folder, however, I did copy it there correctly as per my knowledge.
I also did try to edit the system Environment Variables with following path: C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.7\bin
I am using TensorRT 7.1.3.4. (I did have 8.5 version, but it is not supported by my GPU due to computing power [I am running 2060 super])
and cudnn 8.8.1.3
Any advise?
Thank you,
David
