Filters in "deepstream-infer-tensor-meta-test" don't do anything
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1
• TensorRT Version 8+
• NVIDIA GPU Driver Version (valid for GPU only) 510.85
• Issue Type( questions, new requirements, bugs) Question
I am testing out the “deepstream_infer_tensor_meta.cpp” example as I am looking to implement something similar, and noticed for both the pgie, and sgies the “class-attrs-all” and “classifier-threshold” respectively don’t actually do anything. Is there any way to get them to actually be applied? It would just be nicer then adding them in manually.
FYI, to determine that they weren’t applied I…
  1. Set “detectionParams.perClassPreclusterThreshold = {0.0, 0.0, 0.0, 0.0};” on line 210 in “deepstream_infer_tensor_meta_test.cpp”
  2. Set attributes in “[class-attrs-all]” in “dstensor_pgie_config.txt” as
[class-attrs-all]
pre-cluster-threshold=0.99999
topk=1
nms-iou-threshold=0.01
3.) Set “classifier-threshold=0.99” in all sgie configs.
network-type=100
output-tensor-meta=1
if network-type is 100, you need to implement post processing in callback function, in pgie_pad_buffer_probe, sgie_pad_buffer_probe, you can define own perClassPreclusterThreshold .
