I want to find the min value in a file
I have kernel to find the min
but when I print the value is error
the min value is 192.972198 in the file
bur print the result is 265.335815 in the src
please help me to finding error
(As a disclaimer, I didn’t look at your code…)
You can use the CUDPP/Thrust/OpenCV_GPU library to find the min or max in an array also. Only takes a few lines of code with those
