What we were training for
We run a 10-agent analyst “Room” for a trading-education product (simulation only). The agent that matters most reads a fundamentals brief and writes an analyst report. We wanted it better at the things a careful analyst does and a general model doesn’t:
- Basis discipline — don’t compare an annual figure to a quarterly one, or gross debt to net debt; when a brief is ambiguous about basis, say so
- Don’t invent conflicts — two sources differing by definition (cash vs cash+equivalents) is not a data conflict, and calling it one is a detectable failure
- Ratio and trend reasoning grounded in the statements, not plausible-sounding prose
- Earnings-quality flags — accruals vs cash flow, receivables outrunning revenue
- As-of-date discipline, and refusing when the brief can’t answer
All programmatically checkable, which is why we picked them.
What we did
BASE
fastino/Fastino-Nemotron-3.5-Lightning-Finance — 31.6B hybrid Mamba-MoE. Note it is already a finance fine-tune; it beat a general 35B model 43/44 vs 21/43 on our basis rubric, which is why we built on it.
LORA
r=32, α=64, lr 1e-4, cosine, 2 epochs, bs=1 × grad-accum 16, bf16, seq len 4096
TARGETS
attention q/k/v/o + Mamba in_proj + shared-expert up/down — 93 modules, 22.7M trainable. Routed experts frozen.
HARDWARE
single DGX Spark GB10, 121GB unified memory, ~17h for the successful run
EVAL
468 held-out prompts, 8 surfaces, scored by the same programmatic checks that generated the training labels; held-out tickers disjoint from training
| DATA SOURCE | SHARE | WHAT |
| Our generators | 51% | Briefs from real filings where the label is computed, not judged |
| Public finance SFT | 41% | FinQA, TAT-QA, financial-RLVR, Finance-Instruct |
| Chat replay | 8% | UltraChat slice, anti-forgetting |
Output formatting was one recipe of sixteen — 8% of the mix, and not the point.
What we wanted
Measurable movement on those capabilities — fewer basis errors, fewer invented conflicts, more correct refusals. We’d have accepted a few points on any one of them.
What we got
| CAPABILITY TARGETED | BASE | FINE-TUNED |
| Analyst report correctness | 43/44 | 43/44 |
| False conflicts invented (lower better) | 0/44 | 2/44 |
| Correct refusals | 45% | 50% |
Parity on quality, slightly worse on invented conflicts, refusals inside the noise.
The only thing that moved was output formatting — the 8%. And when we finally ran the control, decode-time schema constraint got the untrained model to the same place in ~50 minutes:
| FORMATTING CHECK | BASE | BASE + GRAMMAR | FINE-TUNED |
| Size-ladder compliance | 57% | 100% | 100% |
| Trader block parses | 26% | 100% | 100% |
So the one gain didn’t need training either. n=69 and n=68.
Two process failures of ours, in case they invalidate the result for you.
37% of our first eval set was verbatim training data — three surfaces were generated by calling the training-data generators. We caught it and rebuilt them; every number above is from the clean set. We also found six defects in our scoring harness, in both directions, all fixed before these numbers.
WHAT WE’RE ASKING
Is this expected?
Should ~10k programmatically-labelled analytical examples move this class of capability with SFT at all? Everything we taught is verifiable, but we taught it as next-token prediction over a correct answer — which may simply be the wrong lever.
Is it the base?
Stacking LoRA on a model already fine-tuned for finance may leave no headroom, or fight the existing adaptation. Should we train from the vanilla instruct model and accept losing its finance skills?
Is it capacity?
r=32 / 22.7M trainable on a 31.6B MoE with routed experts frozen. Too small a surface to move reasoning, as opposed to style?
Is RL the honest answer?
Every label we have is verifiable — the RLVR/GRPO setup. Is SFT just the wrong tool for “stop making this class of error”?
Should we do anything at all?
Genuine question. The formatting win is free via grammars, and the base is already decent at the analysis. Is there a version of this worth another run, or is the right answer to stop and spend the effort on retrieval and tooling instead?
