Trying to finetune the pretrained nemo model with below command
python speech_to_text_ctc_bpe.py --config-path=“/path/to/confiig/file” --config-name=“conformer_ctc_bpe_v13” trainer.max_epochs=50 +init_from_nemo_model=“path/to/stt_hi_conformer_ctc_medium.nemo”
Getting error as shown below:
from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.norm_self_att.weight: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.norm_self_att.bias: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.self_attn.pos_bias_u: copying a param with shape torch.Size([4, 64]) from checkpoint, the shape in current model is torch.Size([8, 64]).
size mismatch for encoder.layers.17.self_attn.pos_bias_v: copying a param with shape torch.Size([4, 64]) from checkpoint, the shape in current model is torch.Size([8, 64]).
size mismatch for encoder.layers.17.self_attn.linear_q.weight: copying a param with shape torch.Size([256, 256]) from checkpoint, the shape in current model is torch.Size([512, 512]).
size mismatch for encoder.layers.17.self_attn.linear_q.bias: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.self_attn.linear_k.weight: copying a param with shape torch.Size([256, 256]) from checkpoint, the shape in current model is torch.Size([512, 512]).
size mismatch for encoder.layers.17.self_attn.linear_k.bias: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.self_attn.linear_v.weight: copying a param with shape torch.Size([256, 256]) from checkpoint, the shape in current model is torch.Size([512, 512]).
size mismatch for encoder.layers.17.self_attn.linear_v.bias: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.self_attn.linear_out.weight: copying a param with shape torch.Size([256, 256]) from checkpoint, the shape in current model is torch.Size([512, 512]).
size mismatch for encoder.layers.17.self_attn.linear_out.bias: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.self_attn.linear_pos.weight: copying a param with shape torch.Size([256, 256]) from checkpoint, the shape in current model is torch.Size([512, 512]).
size mismatch for encoder.layers.17.norm_feed_forward2.weight: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.norm_feed_forward2.bias: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.feed_forward2.linear1.weight: copying a param with shape torch.Size([1024, 256]) from checkpoint, the shape in current model is torch.Size([2048, 512]).
size mismatch for encoder.layers.17.feed_forward2.linear1.bias: copying a param with shape torch.Size([1024]) from checkpoint, the shape in current model is torch.Size([2048]).
size mismatch for encoder.layers.17.feed_forward2.linear2.weight: copying a param with shape torch.Size([256, 1024]) from checkpoint, the shape in current model is torch.Size([512, 2048]).
size mismatch for encoder.layers.17.feed_forward2.linear2.bias: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.norm_out.weight: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for encoder.layers.17.norm_out.bias: copying a param with shape torch.Size([256]) from checkpoint, the shape in current model is torch.Size([512]).
size mismatch for decoder.decoder_layers.0.weight: copying a param with shape torch.Size([129, 256, 1]) from checkpoint, the shape in current model is torch.Size([129, 512, 1]).
Can you please help out with the error?
