I can’t figure out what firmware to use for MT_04A0110001 (Voltaire 500 EX-D dual port). The information of the device is listed as:
Image type: FS2
FW Version: 2.7.700
Device ID: 25408
Description: Node Port1 Port2 Sys image
GUIDs: 0008f104039a1ea5 0008f104039a1ea6 0008f104039a1ea7 0008f104039a1ea8
MACs: 000000000000 000000000001
VSD: VLT-HRM
PSID: MT_04A0110001
The reason why I’m trying to upgrade the firmware is to check if that will fix the following error that appears when opensm (from MLNX_VPI_WinOF-4_80_All_win2012R2_x64.exe) is started on windows server 2012 r2 :
“Mellanox ConnectX IPoIB Adapter device reports a “Modify QP error” on qpn #0x20b8 Status #0xffffffea. Therefore, the HCA Nic will be reset. (The issue is reported in Function CMcast::CompleteJoinMcastWi).” (This message is flooding the windows server event log several times a second…)
Also, %windir%\temp\osm.log is flooded with thousands of lines repeating the same thing:
log_notice: Reporting Generic Notice type:3 num:66 (New mcast group created) from LID:1 GID:ff12:401b:ffff::ffff:ffff
log_notice: Reporting Generic Notice type:3 num:67 (Mcast group deleted) from LID:1 GID:ff12:401b:ffff::ffff:ffff
Could this may be an issue related to OpenSM only?
Thanks in advance!
Lars.
