Hello i am trying to flash an Orin Nano that already has its PKC and SBK fuses burned and therefore secure boot activated. Below is the command:
Environment:
- Host: Ubuntu 20.04
- Jetpack 6.2
- Connected via USB-C
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -u keys/rsa_priv.pem -v keys/sbk.key --external-device mmcblk0p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
but it fails, below is the log (initrd.log)
initrd.log (215.6 KB)
I tried passing the variables to the command. I read this variables with flash.sh --read-info -u pkc.key -v sbk.key:
sudo BOARDID=3767 BOARDSKU=0005 FAB=300 BOARD_REV="N.2" CHIP_SKU="00:00:00:D5" ./tools/kernel_flash/l4t_initrd_flash.sh -u keys/rsa_priv.pem -v keys/sbk.key --external-device mmcblk0p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
but fails to finish flash process succesfully and asks to run another command (initrd2.log):
initrd2.log (424.7 KB)
here is the message after running the flashcmd script
sudo bash ./flashcmd.txt
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0337 ] mb1_t234_prod_aligned_sigheader_encrypt.bin.signed filename is from --mb1_bin
[ 0.0337 ] psc_bl1_t234_prod_aligned_sigheader_encrypt.bin.signed filename is from --psc_bl1_bin
[ 0.0337 ] rcm boot with presigned binaries
[ 0.0357 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader_encrypt.bin.signed --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader_encrypt.bin.signed --download bct_mb1 mb1_bct_MB1_sigheader_encrypt.bct.signed
[ 0.0366 ] BR_CID: 0x89012344705DE5196C000000100102C0
[ 0.2443 ] Sending bct_br
[ 0.4656 ] Sending mb1
[ 0.4676 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader_encrypt.bin.signed --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader_encrypt.bin.signed --download bct_mb1 mb1_bct_MB1_sigheader_encrypt.bct.signed
I wanted to ask for some help on this topic to be able to flash using command line.
It is worth mentioning that flashing with the GUI (SDKManager) works just fine. The device boots up correctly. That raises a question. How is that possible if the GUI does not have access to the private key to sign the boot codes?
hello cristian.hidalgo,
however, flashing through SDKManager it did not provide any keys.
it doubts how you fuse a target, may I have your steps and fusing logs for reference.
yes, for sure. I followed the steps on the FSKP guide.
I created an RSA 3k key for PKC fuse and a 32 byte sbk key for SBK fuse. Below is the configuration file:
<genericfuse MagicId="0x45535546" version="1.0.0">
<fuse name="PublicKeyHash" size="64" value="0x99a6b7d25ffd5d7cc49bf2612d01d7fe58b5121f9c473748728232bc114c25ae2415d56666157c79fc9bf0e3b4445344ff8af51a64f334289912cdff7414fa00"/>
<fuse name="SecureBootKey" size="32" value="0x8acf54e1c1372a143fd79873d16111174f8d7450c2e93597d6e019c0d3a3952f"/>
<fuse name="BootSecurityInfo" size="4" value="0x9"/>
</genericfuse>
and then to burn the fuses you can take a look at the following logs:
- delete1.log: command to generate real fuse blob and its output
- delete2.log: command to actually burn fuses and its output
- delete3.log: UART output from the board
delete.log (57.1 KB)
delete2.log (1.0 KB)
delete3.log (175.6 KB)
Let me know if you need anything else
please execute below on your target to parse the fuse info
for instance. $ sudo /usr/sbin/nv_fuse_read.sh
Hello @JerryChang
below, is the output:
nvidia@tegra-ubuntu:~$ sudo /usr/sbin/nv_fuse_read.sh
[sudo] password for nvidia:
odm_lock: 0x00000000
revoke_pk_h0: 0x00000000
revoke_pk_h1: 0x00000000
optin_enable: 0x00000000
public_key_hash: 0x99a6b7d25ffd5d7cc49bf2612d01d7fe58b5121f9c473748728232bc114c25ae2415d56666157c79fc9bf0e3b4445344ff8af51a64f334289912cdff7414fa00
boot_security_info: 0x00000009
odmid: 0x0000000000000000
pk_h1: 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
pk_h2: 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
security_mode: 0x00000000
reserved_odm2: 0x00000000
reserved_odm3: 0x00000000
reserved_odm0: 0x00000000
reserved_odm1: 0x00000000
reserved_odm6: 0x00000000
reserved_odm7: 0x00000000
reserved_odm4: 0x00000000
reserved_odm5: 0x00000000
odminfo: 0x00000000
system_fw_field_ratchet1: 0x00000000
system_fw_field_ratchet0: 0x00000000
system_fw_field_ratchet3: 0x00000000
system_fw_field_ratchet2: 0x00000000
ecid: 0x8472633b5f40040b
FYI,
please refer to Jetson Orin Fuse Specification.
Bits [8:4] Not available and may not be logic 0 by default
recently, in T234 chips fuse v70, the fuse value for boot_security_info was burned (by manufacturing) to 0x1E0
you should update the content of fuse-config.xml “BootSecurityInfo” value to set 0x1E9
for your use-case.
Hello, @JerryChang
Thanks for the help so far.
The response raises a couple of questions:
Why is it exactly 1E9? Shouldn’t all the bits be different than 0? in which case it would be 1F9.
Also it is mentioned that the boot_security_info fuse was burned to 1E0 by manufacturing recently, why does it comes as 0x00000009 when reading it? and how recent was this done? does it apply for all Jetson Orin Nano platforms?
those Bits [8:4] has some default values, boot_security_info was burned (by manufacturing) to 0x1E0
Hello @JerryChang
Tried to burn boot_security_info to 1E9 instead of just 9 but did not work.
here is the the fuse config file:
<fuse name="BootSecurityInfo" size="4" value="0x1E9"/>
</genericfuse>
In the following logs are the commands used with their outputs:
log1E92.log (57.1 KB)
log1E91.log (1006 Bytes)
After running these commands and resetting the board, i still read the following fuse values:
odminfo: 0x00000000
Also the board is being flashed with unsigned images and is still booting.
I doubt it’s due to you tested on the same working directory.
could you please download another new JP-6.2 public release, build from scratch, re-flash this target for confirmation.
besides, please also setup serial console to collect complete UART logs.
