albertr
November 19, 2018, 2:11am
#1
Can we just flash (via dd command) a kernel image to eMMC partition directly on Xavier without using recovery mode and flash.sh script?
Here’s the eMMc card partition layout on our Xavier…
Model: MMC HBG4a2 (sd/mmc)
Disk /dev/mmcblk0: 31.3GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 20.5kB 30.1GB 30.1GB ext4 APP msftdata
2 30.1GB 30.1GB 512kB mts-mce msftdata
3 30.1GB 30.1GB 512kB mts-mce_b msftdata
4 30.1GB 30.1GB 4194kB mts-proper msftdata
5 30.1GB 30.1GB 4194kB mts-proper_b msftdata
6 30.1GB 30.1GB 524kB cpu-bootloader msftdata
7 30.1GB 30.1GB 524kB cpu-bootloader_b msftdata
8 30.1GB 30.1GB 393kB bootloader-dtb msftdata
9 30.1GB 30.1GB 393kB bootloader-dtb_b msftdata
10 30.1GB 30.1GB 2097kB secure-os msftdata
11 30.1GB 30.1GB 2097kB secure-os_b msftdata
12 30.1GB 30.1GB 131kB eks msftdata
13 30.1GB 30.1GB 1049kB bpmp-fw msftdata
14 30.1GB 30.1GB 1049kB bpmp-fw_b msftdata
15 30.1GB 30.1GB 1049kB bpmp-fw-dtb msftdata
16 30.1GB 30.1GB 1049kB bpmp-fw-dtb_b msftdata
17 30.1GB 30.1GB 262kB xusb-fw msftdata
18 30.1GB 30.1GB 262kB xusb-fw_b msftdata
19 30.1GB 30.1GB 524kB rce-fw msftdata
20 30.1GB 30.1GB 524kB rce-fw_b msftdata
21 30.1GB 30.1GB 4194kB adsp-fw msftdata
22 30.1GB 30.1GB 4194kB adsp-fw_b msftdata
23 30.1GB 30.1GB 524kB sce-fw msftdata
24 30.1GB 30.1GB 524kB sce-fw_b msftdata
25 30.1GB 30.1GB 6291kB sc7 msftdata
26 30.1GB 30.1GB 6291kB sc7_b msftdata
27 30.1GB 30.2GB 134MB BMP msftdata
28 30.2GB 30.4GB 134MB BMP_b msftdata
29 30.4GB 30.4GB 67.1MB kernel msftdata
30 30.4GB 30.5GB 67.1MB kernel_b msftdata
31 30.5GB 30.5GB 524kB kernel-dtb msftdata
32 30.5GB 30.5GB 524kB kernel-dtb_b msftdata
33 30.5GB 30.5GB 1049kB CPUBL-CFG msftdata
34 30.5GB 30.5GB 8389kB RP1 msftdata
35 30.5GB 30.5GB 8389kB RP2 msftdata
36 30.5GB 31.3GB 743MB UDA msftdata
Wow, 36 partitions, how more complicated it can get?
-albertr
albertr
November 19, 2018, 2:14am
#2
So partition #29 looks interesting? How about the following?
dd if=zImage of=/dev/mmcblk0p29 ???
Would it work or not?
-albertr
hello albertr,
I haven’t tried to update kernel partition with dd commands,
however, you should note that Xavier was encrypt boot.img and flashing that into kernel partition.
system will not able to boot-up if you just overwrite the zImage with your own build image.
here’s part of flashing message for your reference.
$ sudo ./flash.sh -r -k kernel jetson-xavier mmcblk0p1
[ 15.5855 ] Writing partition
[ 15.5868 ] tegradevflash_v2 --write kernel boot_sigheader.img.encrypt
[ 15.5882 ] Bootloader version 01.00.0000
[ 15.6855 ] Writing partition kernel with boot_sigheader.img.encrypt
[ 15.6860 ] [................................................] 100%
albertr
November 19, 2018, 3:05pm
#4
This encryption is BS, considering the price NVidia is charging for Xavier… it should not be a closed platform. Where decryption part is done? In the boot-loader?
-albertr
hello albertr,
we will investigate this internally,
will get back to you while we come out some conclusions, thanks
hello albertr,
I will still suggest you using flash script to update kernel partition.
however, if you want to update the kernel remotely.
please follow below steps to encrypt the boot image, and using the dd commands to update it.
thanks
to compiler the kernel sources, and copy the Image file to output folder
convert kernel image (Image) into boot.img,
./mkbootimg --kernel $OUT/kernel/Image --ramdisk initrd --board mmcblk0p1 --output boot.img
commands to generate an encrypt boot.img
sudo ./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --chip 0x19 --applet mb1_t194_prod.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --cfg flash.xml --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos_t194.img; eks eks.img; kernel boot.img; kernel_dtb tegra194-p2888-0001-p2822-0000.dtb; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb" --cmd "sign boot.img"
copy the encrypted boot.img to your target device.
check the kernel partition, you could check the partition id as below,
$ ls -al /dev/disk/by-partlabel
lrwxrwxrwx 1 root root 16 Dec 5 04:32 kernel -> ../../mmcblk0p29
using dd commands to overwrite the kernel partition, and perform warm-reboot to take effect.
$ sudo dd if=/tmp/boot_sigheader.img.encrypt of=/dev/mmcblk0p29
$ sudo reboot
I am curious…I see “–ramdisk initrd”. Does cboot load a ramdisk directly? Or is this just something needed for an indirect effect?
again, these steps should be developing testing only.
“–ramdisk initrd” command just something needed for mkbootimg binary to convert Image into boot.img file.
thanks
cuongm
April 12, 2019, 6:37pm
#9
where is ‘initrd’ located?
Hi JerryChang,
I tried the command below you mentioned, which didn’t update the kernel.
I’m trying another method you mentioned to generate the boot.img…
lrwxrwxrwx 1 root root 16 Des 6 10:00 kernel -> ../../mmcblk0p30
$ sudo dd if=/tmp/boot_sigheader.img.encrypt of=/dev/mmcblk0p30
Failed to open ‘/tmp/boot_sigheader.img.encrypt’, No such file or directory. I’m using Jetpack 4.2.2 for Xavier and try to update the kernel without erasing existing contents.
Or does NVidia have a better way to do this?
Hi JerryChang,
Thanks, solved.
