I am trying to use asynchronous IO to overlap GPU computations and file writing without success at the moment.
So I create a small example to perform asynchronous write that also crashes.
Here the code
program io
use ISO_FORTRAN_ENV
implicit none
character(len=256) :: message
integer(kind=2) :: stat = 0
integer :: i
real :: a, b, c
integer :: id
real, dimension(1024*1024) :: tab
namelist /var/i, a, b, c
open( UNIT=1, &
FILE="io_2_.data", &
ACCESS="direct", &
ASYNCHRONOUS="yes", recl=4*1024*1024 )
call random_number( tab )
write( UNIT=1, rec=1, ASYNCHRONOUS="yes", ID=id) tab
print *, "I am waiting"
WAIT( UNIT=1,ID=id )
write( UNIT=1, rec=2, ASYNCHRONOUS="yes", ID=id) tab
WAIT( UNIT=1, ID=id )
close( UNIT=1 )
end program io
It returns the following
PGFIO-F-255/unformatted write/unit=1/illegal asynchronous I/O operation.
File name = io_2_.data unformatted, direct access record = 1
In source file test_io.f90, at line number 19
Do you have any explanations on this error code ?
Thank you
