I’m fairly new to RDMA and have a situation where I’m attempting to send UDP packets from an FPGA via 40gigE and be able to place them directly into GPU memory via a Mellanox Connectx5 card. My goal is to not have to create a full TCP stack in the FPGA to handle an RC QP type connection between the two devices but use a UD QP at the server and have it receive properly formatted UD messages from the FPGA.
I believe I can do this since the UD message appears to be a self contained message defining the RECV IBV type as well as the datagram.
I’ve also seen the examples with the QPT_RAW_PACKET type and was curious if this was possible to use at the server and still be able to place the data directly into the GPU allocated memory.
