Frame = pyds.get nvds buf_surface(bash(gst buffer), frame meta.batch id)RuntimeError: get nvds buf_Surface: Currently we only support RGBA color Forma
**• Hardware Platform (Jetson / GPU)**Jetson
• DeepStream Version 5.0
**• JetPack Version (valid for Jetson only)**4.6
• TensorRT Version 7.1.3.0
**• Issue Type( questions, new requirements, bugs)**bugs
在tiler_src_pad_buffer_probe中报以下错frame = pyds.get nvds buf_surface(bash(gst buffer), frame meta.batch id)RuntimeError: get nvds buf_Surface: Currently we only support RGBA color Format,但是在osd_sink_pad_buffer_probe同样的代码没有报错?这是为什么?
You need to add nvvideoconvert and capsfilter before tiler. The following is the reference code.
    print("Creating nvvidconv1 \n ")
    nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
    if not nvvidconv1:
        sys.stderr.write(" Unable to create nvvidconv1 \n")
    print("Creating filter1 \n ")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
    if not filter1:
        sys.stderr.write(" Unable to get the caps filter1 \n")
    filter1.set_property("caps", caps1)
Please discuss in English, thanks.
ok ,thanks。
