Hallo :)
I did as suggested and updated my BIOS to the latest version. I now was able to set the memory to the correct values:
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 2.8 present.
Handle 0x0018, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x0010
Error Information Handle: 0x0017
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: Unknown
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL A
Type: Unknown
Type Detail: Unknown
Speed: 3200 MT/s
Manufacturer: Unknown
Serial Number: Unknown
Asset Tag: Not Specified
Part Number: Unknown
Rank: Unknown
Configured Memory Speed: 3200 MT/s
Minimum Voltage: Unknown
Maximum Voltage: Unknown
Configured Voltage: Unknown
Handle 0x001A, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x0019
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 3200 MT/s
Serial Number: 00000000
Part Number: CMK32GX4M2E3200C16
Rank: 1
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
Handle 0x001D, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x001C
Data Width: Unknown
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL B
Type: Unknown
Speed: 3200 MT/s
Rank: Unknown
Handle 0x001F, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x001E
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR4
Speed: 3200 MT/s
Rank: 1
I performed serveral rounds of memtest (uefi version) without errors
After that I started a phronix test suite (blender with classroom and all tests enabled) The whole desktop freezes after 5 minutets and I was able to get my journalctl logs as here:
Mär 21 15:55:35 simon-pc kernel: NVRM: GPU at PCI:0000:27:00: GPU-7d3b6aed-f953-cfb6-a4d5-3222cda5768f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 0, TPC 0): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x504648=0xe0009 0x504650=0x0 0x504644=0xd3eff2 0x50464c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 0, TPC 1): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x504e48=0x150009 0x504e50=0x20 0x504e44=0xd3eff2 0x504e4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 0, TPC 2): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x505648=0xe0009 0x505650=0x20 0x505644=0xd3eff2 0x50564c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 0, TPC 3): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x505e48=0x150009 0x505e50=0x20 0x505e44=0xd3eff2 0x505e4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 1, TPC 0): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x50c648=0x110009 0x50c650=0x20 0x50c644=0xd3eff2 0x50c64c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 1, TPC 1): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 1, TPC 1): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x50ce48=0xb0009 0x50ce50=0x24 0x50ce44=0xd3eff2 0x50ce4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 1, TPC 2): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 1, TPC 2): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x50d648=0x140009 0x50d650=0x24 0x50d644=0xd3eff2 0x50d64c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 1, TPC 3): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x50de48=0x100009 0x50de50=0x20 0x50de44=0xd3eff2 0x50de4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 1, TPC 4): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x50e648=0x20009 0x50e650=0x20 0x50e644=0xd3eff2 0x50e64c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x514648=0x0 0x514650=0x20 0x514644=0xd3eff2 0x51464c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x514e48=0x0 0x514e50=0x20 0x514e44=0xd3eff2 0x514e4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 2, TPC 2): Out Of Range Address
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x515648=0x103000e 0x515650=0x20 0x515644=0xd3eff2 0x51564c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x515e48=0x0 0x515e50=0x20 0x515e44=0xd3eff2 0x515e4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 2, TPC 4): Out Of Range Address
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x516648=0x11e000e 0x516650=0x20 0x516644=0xd3eff2 0x51664c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 3, TPC 0): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 3, TPC 0): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x51c648=0x4140009 0x51c650=0x24 0x51c644=0xd3eff2 0x51c64c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 3, TPC 1): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 3, TPC 1): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x51ce48=0x40d0009 0x51ce50=0x24 0x51ce
4=0xd3eff2 0x51ce4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 3, TPC 2): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 3, TPC 2): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x51d648=0x4100009 0x51d650=0x24 0x51d644=0xd3eff2 0x51d64c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 3, TPC 3): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 3, TPC 3): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x51de48=0x4010009 0x51de50=0x24 0x51de44=0xd3eff2 0x51de4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 3, TPC 4): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 3, TPC 4): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x51e648=0x4120009 0x51e650=0x24 0x51e644=0xd3eff2 0x51e64c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 4, TPC 0): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 4, TPC 0): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x524648=0x4170009 0x524650=0x24 0x524644=0xd3eff2 0x52464c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 4, TPC 1): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 4, TPC 1): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x524e48=0x40d0009 0x524e50=0x24 0x524e44=0xd3eff2 0x524e4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 4, TPC 2): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 4, TPC 2): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x525648=0x41c0009 0x525650=0x24 0x525644=0xd3eff2 0x52564c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 4, TPC 3): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 4, TPC 3): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x525e48=0x40f0009 0x525e50=0x24 0x525e44=0xd3eff2 0x525e4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 4, TPC 4): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Global Exception on (GPC 4, TPC 4): Physical Multiple Warp Errors
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x526648=0x41d0009 0x526650=0x24 0x526644=0xd3eff2 0x52664c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 5, TPC 0): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x52c648=0xa0009 0x52c650=0x20 0x52c644=0xd3eff2 0x52c64c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 5, TPC 1): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x52ce48=0x120009 0x52ce50=0x20 0x52ce44=0xd3eff2 0x52ce4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 5, TPC 2): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x52d648=0x180009 0x52d650=0x20 0x52d644=0xd3eff2 0x52d64c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics SM Warp Exception on (GPC 5, TPC 3): Illegal Instruction Encoding
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 13, pid=695, Graphics Exception: ESR 0x52de48=0xd0009 0x52de50=0x20 0x52de44=0xd3eff2 0x52de4c=0x17f
Mär 21 15:55:35 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 31, pid=13526, Ch 00000043, intr 10000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_1 faulted @ 0x7fc5_3e66c000. Fault is of type FAULT_PDE ACCESS_TYPE_WRITE
Mär 21 15:55:36 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 32, pid=357, Channel ID 00000002 intr 00800000
Mär 21 15:55:36 simon-pc kernel: sched: RT throttling activated
Mär 21 15:55:37 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 32, pid=357, Channel ID 00000002 intr 00800000
Mär 21 15:55:37 simon-pc kernel: NVRM: Xid (PCI:0000:27:00): 62, pid=695, 0a97(2a90) 00000000 00000000
The RAM wasn’t quite used much (2.4GBs) the GPU temp was at 71°C the CPU cores don’t get used (1 core at 100% at a time)
The power supply can’t be the reason (new BeQUiet! 600w Gold) should be enough for the system.
I’m still not sure how I can fix it. I’m sorry and I am quiet desperate because I really can’t find the reason. Do you have an idea?
